Jul 21, 2005 - 5:19 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
I broke my antenna about a month ago, and just today I took it apart, glued it do its always down, and attached some speaker wire to it for reception, sort of as described in here: http://www.6gc.net/index.php?action=howto&itu=36
The thing is, my reception isnt all that great. The speaker wire I used wasnt that thick, could that have something to do with it? Also, I tried attaching the wire to my frame and found that in doing that, I'd loose all reception, why is that? Is there an optimal wire guage and legnth/ any tricks for getting a really good reception without an antenna? thanks. |
Jul 21, 2005 - 6:34 PM
Enthusiast ![]() Joined Dec 11, '03 From Monterey, CA Currently Offline Reputation: 0 (0%) |
QUOTE(CheesyLobster @ Jul 21, 2005 - 10:19 PM) I broke my antenna about a month ago, and just today I took it apart, glued it do its always down, and attached some speaker wire to it for reception, sort of as described in here: http://www.6gc.net/index.php?action=howto&itu=36 The thing is, my reception isnt all that great. The speaker wire I used wasnt that thick, could that have something to do with it? Also, I tried attaching the wire to my frame and found that in doing that, I'd loose all reception, why is that? Is there an optimal wire guage and legnth/ any tricks for getting a really good reception without an antenna? thanks. [right][snapback]315171[/snapback][/right] I'm sorry I can't answer your question about optimal wire guages and such, but I must ask: Why not just do the S2000 antenna conversion? It's easy, it's cheap, and it looks better than having no antenna (not to mention better reception). I am sure that I'm not alone in urging you to try it... - Lu-Tang -------------------- "To be the man, you have to beat the man..."
Jul 21, 2005 - 8:19 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
When you attached the wire to the frame you gave the stereo an extra ground, don't do that again, you could blow the stereo. You could do what I did, buy a power antenna and make a switch for it. Or S2000 antenna.
Jul 21, 2005 - 8:52 PM
Enthusiast ![]() ![]() Joined Apr 16, '03 From Los Angeles CA Currently Offline Reputation: 3 (100%) |
where is a good place to get an s2000 antenna??? and how much do they run for??
Jul 21, 2005 - 9:13 PM
eBay, or your local Honda dealer. It shouldn't be more than $30.
Jul 21, 2005 - 9:40 PM
QUOTE(Cutrara @ Jul 21, 2005 - 8:19 PM) When you attached the wire to the frame you gave the stereo an extra ground, don't do that again, you could blow the stereo. You could do what I did, buy a power antenna and make a switch for it. Or S2000 antenna. [right][snapback]315228[/snapback][/right] agreed. Power antenna w/switch -------------------- |
Jul 21, 2005 - 10:32 PM
Batman, you're the one that convinced me to convert to a power antenna, too lol.
Jul 21, 2005 - 10:33 PM
QUOTE(Cutrara @ Jul 21, 2005 - 10:32 PM) Batman, you're the one that convinced me to convert to a power antenna, too lol. [right][snapback]315284[/snapback][/right] stop it, your gonna make me blush -------------------- |
Jul 21, 2005 - 11:24 PM
Enthusiast ![]() Joined Jun 17, '05 Currently Offline Reputation: 0 (0%) |
I don't have an atenna and i get good reception....all i have is like the little knobby thing the antenna goes in. Sometimes ONE channel outta the 6 i listen to goes fuzzy, and that hardly happens. Plus i kind of do like the look of no antenna.
Jul 22, 2005 - 12:17 AM
eBay is the way
Jul 22, 2005 - 1:29 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I agree.. Power antenna with switch... cuz I had a rubber antenna after i took the power one out (too ugly that tall) but the reception wasn't great at all... plus someone stole it :-P... So i went and bought a 31" universal power antenna (Ebay $ 50) and installed it with a switch... so now i can leave it down while listening to cd's but put it up when listening to radio and get awesome reception!
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jul 22, 2005 - 11:22 AM
http://www.antennax.com/toyota/celica.htm
Power Antenna Kit: $29.99, Same one I have, install was easy. -------------------- |
Jul 23, 2005 - 7:27 AM
Ive replaced the antenna before, I just dont really want to spend the money if I dont have too. could i maybe attach the antenna to any wire in the car, or would that be the same as grounding it on the frame?
Jul 23, 2005 - 8:39 AM
I wouldn't do that, because you'd again be giving it power through the antenna wire. Get a high-gauge wire with thin insulation and connect it to the antenna wire, but remember, you need 2 wires for it to recieve RF signals. Attach one to the pin on the antenna jack and on on the base. Run it somewhere high in the car.
| Lo-Fi Version | Time is now: September 21st, 2026 - 5:15 AM |
