Jul 25, 2005 - 12:47 PM
About 2 or 3 times in a week, i start my car up in the morning, cranks over but dies, so i have to start it and give it gas to keep it alive...could this be a clogged fuel filter or something more? it seems to be lacking the gas flow...plz help a brotha out.
Jul 25, 2005 - 1:26 PM
could be fuel filter, or worn ignition components, or a million other little things..lol
the fuel filter may be a good place to start, its relitivly cheap about 20$ or so.. -------------------- Former Team 5SFTE pro member ;)
Jul 25, 2005 - 1:37 PM
well i got it replaced at toyota last year, do they go bad that fast?
Jul 25, 2005 - 2:54 PM
QUOTE(LewFX @ Jul 25, 2005 - 6:37 PM) well i got it replaced at toyota last year, do they go bad that fast? [right][snapback]316629[/snapback][/right] They don't go out that fast... but look into it just to be sure. Besides that, your ignition system... -------------------- "It's ok to be naked girl... I'm an artist!"
Jul 25, 2005 - 3:35 PM
last time toyota changed out the O2 sensor and it worked for awhile but still happened. they blame toyota for not making a good 02 sensor.
Jul 25, 2005 - 4:13 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
if it were your o2 sensor you may be using some kind of bad gas, but after you get it running how does it run?
-------------------- AIM : FAQdaWorld
Jul 25, 2005 - 4:23 PM
runs fine after, just sometimes doesnt wanna start in the morning.
Jul 25, 2005 - 5:55 PM
Cold start injector perhaps? or are the 5sfe's equipped w/ this?
Jul 28, 2005 - 5:39 PM
okay same thing happened again today, start it, die, start it again with some a little gas, shakinnnn, die, start it, hold gas, switch gears into reverse, runs fine...45 minutes of traffic on freeway, get to a stop sign near my work, turn a/c on, car dies!!!....what the hell is wrong with this picture...plzzz help.
Jul 28, 2005 - 9:21 PM
how was it running at idle before u flipped on the ac? Could be a proble w/ the idle up thingy (forget its exact name).
It could still be a large number of things. What was the temp. when u went to start it today? -------------------- AIM : FAQdaWorld
Jul 28, 2005 - 10:36 PM
ya it ran fine when i went to work but before i actually got there i had to stop at a light. ide seemed fine, flipped on a/c and died. temp in the morning was nice maybe 50-60
Jul 29, 2005 - 2:14 AM
Does it start back up okay after it dies? To be honest I'm not sure at all what you have going on, just trying to narrow down problems that I've had ya know?
Check your spark plugs if you dont mind, and check it they are fouled out? -------------------- AIM : FAQdaWorld
Jul 29, 2005 - 2:22 AM
check you ignitor cable for any cuts... then all the sprake plug cables.... check your ground wires for rust ... ..
Jul 29, 2005 - 3:05 AM
![]() Enthusiast ![]() ![]() Joined Dec 3, '04 From torrance, ca Currently Offline Reputation: 0 (0%) |
Something like that happened to my celi awhile back. Cold mornings I'd have to gas it for a bit to keep the engine going and on steep inclines or use of A/C when I would come to a stop the rpms would drop down and the car would shudder and then the engine would die. Try replacing the IAC I replaced that and everything was hunkey dory
Jul 29, 2005 - 8:50 AM
can anyone help me find this part for less than $225!!
This post has been edited by LewFX: Jul 29, 2005 - 9:17 AM -------------------- ![]() |
Jul 29, 2005 - 10:19 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '05 From Indianapolis Currently Offline Reputation: 0 (0%) |
my god dude, im having this trouble with my celica this morning too!! Tho it is at least 70 outside today. I give it gas but it still dies, i cant get the engine warm.
Jul 29, 2005 - 11:36 AM
found the AIC for $160!
Jul 31, 2005 - 12:53 AM
new update, i installed the AIC and a new rebuilt aternator, so far so good, but ill know more in the mornings...car is idling nicely now.
Oct 6, 2005 - 2:00 PM
Enthusiast Joined Aug 16, '04 From California Currently Offline Reputation: 0 (0%) |
Oct 6, 2005 - 2:03 PM
the air control valve...clean it with carb cleaner or get another one for $175+
| Lo-Fi Version | Time is now: September 16th, 2026 - 2:46 AM |
