Jul 27, 2005 - 7:57 AM
Enthusiast ![]() Joined Mar 17, '05 From Northridge, CA Currently Offline Reputation: 0 (0%) |
So far: 400mhz gain on the proc (15%), and 125mhz gain on the gf fx 5900xt (30%). Can't wait til i get the Thermal Electric Coolers running...
i'm only slightly nuts: ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Jul 27, 2005 - 8:03 AM
Enthusiast ![]() ![]() ![]() Joined Nov 26, '03 From Texas Currently Offline Reputation: 1 (100%) |
wow, thats impressive, what brand and model is it?
-------------------- It's not just about getting from point A to point B anymore....
Jul 27, 2005 - 8:32 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
To say at least, its not practical
-------------------- JDM Powerplant installed, BPU coming very soon!
Jul 27, 2005 - 12:51 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 16, '04 From San Diego Currently Offline Reputation: 0 (0%) |
Definitely mojo points. But how about some benchmarks?
Jul 27, 2005 - 2:06 PM
na man, now that ive met you in person, you are verey nuts!
Jul 28, 2005 - 6:28 AM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) |
dude fix that flat spot in the first pic. and what pump are you running cause your head flow must suck ass with that much tubing.
none the less its nice to see other W/cing people out there pic of my old setup, ill take pics of my new one in a couple days, building a plexiglass area.
This post has been edited by Sev408: Jul 28, 2005 - 6:28 AM -------------------- hows it taste motha f*cka |
Jul 28, 2005 - 8:45 AM
looks like one of the tubes in the first pic is being kinked, did ur tubes not come w/ springs in them? need to get some, they really help the tubes not kink up so you can get max coolant flow.
Jul 29, 2005 - 7:14 PM
Yeah, the tube was kinking. I'm not really impressed by home-depot's clear vinyl tubing... kinks way too easily. This project was just purely to get the heat and noise away from me when i'm play WoW or D3 or HL2. I still have the system OCed, just a bit.
As far as brands, most of it is custom fabricated. The water blocks i purchased of some dude on ebay about 6 years ago. All of these parts came from my old setup.. back when I was 17 and was aiming for extreme dual TEC + water cooling on my dual celeron Abit BP6 setup. The pump really used to kick ass, it had a head of 20+ ft. but now barely made it past 3 ft. The flow rate was rated at 500gal/hour but now I'm lucky if I see anything more than a trickle. I even took it apart and tried cleaning it; not much improvement. But it gets the job done. This is what I get for spending ALL my extra cash on my ride and nada on my rig. 6 years ago, it was the other way around. Next year when the cash comes in from the new job, I'll build a dual independant cycle system that will work with an array of water blocks and peltiers, something extreme tha will require an anti-freezing agent in one of the cycles. Yes, this isn't very practicle for LAN parties, unless I host them! hehehe ohh yeah, here are the OC results. Nothing too impressive, but its rock stable and its not bad for not using the TEC's right on the CPU/GPU. ![]() Base Mhz: CPU: 3.2ghz --> 3.6 = 12.5% gain RAM: 200mhz --> 225mhz = 12.5% gain GPU: 390mhz --> 514mhz = 31.8% gain RAM: 700mhz --> 923mhz = 31.9% gain One more note: next time I get a water block on the mobo chipset. Very important. |
Jul 29, 2005 - 9:46 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
impresive numbers, gj.
I would consider cutting the length of tubing about 12 feet, that much distance is not gana help the flow, or the ability to cool This post has been edited by creis: Jul 29, 2005 - 9:47 PM -------------------- ![]() |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 11:57 AM |
