> Need Advise, ON dash
post Aug 1, 2005 - 2:53 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
PK heres the dash as of the night of 8/01/05
I'm just wanting some advise on what else to do to make it look better or whatever. any suggestions/ideas are welcome. thanks for any help
post Aug 1, 2005 - 3:52 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Too late now I'm sure, but I think the guages would have looked better above the center A/C vent part of the dash. Where they are now seems kinda dangerous and hard to read while driving. Other than that I'd say make the red piece that used to house the ignition switch fit flush with the dash on the left and right edges and then sand and paint it.
post Aug 2, 2005 - 11:27 AM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
I think it'll look good... jus sand away till it's perfect
post Aug 2, 2005 - 11:37 AM
celicaracer18
Joined May 23, '04
From Meridian, MS
well right now i'm working on making the gauge cluster, that will house the speedo, fuel level and water temp. once thats done i can screw it down and then mold in all the platics around it then just slide in the gauges later, i will be shaving in the plastic piece that goes abouve the gauges, the red piece you see, and the piece that gouse uder the steering column and has the fuse panel in it. i'm also going to shave the vent plasice to the left.
oh and the gauges in the pods to the right wan't be anything i need to look at regularly, i'll just be able to look at them after driving to see how everything is doing all essential gauges will be in gauge cluster or a-pillar.
and i do still have to mount my 5" c2 tach, and i'm not completely sure how i should do it. if i should just mount it where it was before or what
Lo-Fi Version Time is now: August 31st, 2026 - 5:09 AM
