Aug 7, 2005 - 9:55 PM
Enthusiast ![]() Joined Jul 26, '05 From New Carlisle, IN Currently Offline Reputation: 0 (0%) |
some of my friends have been running wires to a switch that can manually turn on the fan that cools your engine. i was just wondering if this will effect everyday driving in my celica. i want a faster car, but i don't want everything to be ruined. so if anybody has any idea what i'm talking about any feedback will be helpful.
Aug 7, 2005 - 9:57 PM
it wont make your car any faster or better. if anything you will probably mess up the relay that makes the fans kick on when the radiator needs cooling...and do more harm then good. i wouldnt mess with it
Aug 8, 2005 - 7:40 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) |
A friend of mine set one up because they were having some serious problems with a cars electronics. Just make sure you run it, and watch your temp gauge..
-------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Aug 8, 2005 - 9:12 PM
I have a manual switch for my fans. The fans are wired directly to a Bosch relay that's wired to my switch which can only be on when the ignition is on. I also have a DEI 528t timer relay that's wired to constant power so that any time I push a pushbutton switch on my switch panel is turns on the fans for about 45 seconds.
Aug 9, 2005 - 7:16 PM
i'm mildly 'under the hood' retarded, so i don't want to splice wires left and right and then have some huge problem with this all, so i guess i won't bother with it. i already have a switch installed by the fuses under my steering wheel, so i guess i can wire a interior neon kit to that. gotta get some use out of it i guess.
Aug 10, 2005 - 12:46 PM
Enthusiast ![]() ![]() ![]() Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) |
no dont do that. do something cool like some fogs maybe, or a fuel pump cut off. or i dunno do something just not neons.
-------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
Aug 10, 2005 - 12:54 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
QUOTE(Coomer @ Aug 8, 2005 - 10:12 PM) I have a manual switch for my fans. The fans are wired directly to a Bosch relay that's wired to my switch which can only be on when the ignition is on. I also have a DEI 528t timer relay that's wired to constant power so that any time I push a pushbutton switch on my switch panel is turns on the fans for about 45 seconds. [right][snapback]322054[/snapback][/right] What inspired you to wire them manually? Did you have to do it because of your swap? Do your fans still have the temperature relay that turns them on when it gets hot enough (So the switches would be like an override) or are they on all the time when the switch is on? That pushbutton thing is neat. Is that something you use after extreme acceleration or something? I feel like I just asked a billion question lol -------------------- |
| Lo-Fi Version | Time is now: August 26th, 2026 - 9:00 PM |
