Aug 12, 2005 - 12:11 AM
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
Still debugging a few things after the swap, but still plannin on body work next week, and then replacing the clutch / few other things.
Really the swap is done now, but I'm looking forward... what should I do next? Twin charge? Or Bigger turbo? Just wanna know what you guys think -FAQ -------------------- AIM : FAQdaWorld
Aug 12, 2005 - 12:25 AM
Enthusiast ![]() Joined Jan 1, '03 From CT Currently Offline Reputation: 0 (0%) |
Twin charge it!! Ive never seen that but always thought designed properly if has a ton of potential. Using the SC for more lowend boost and the turbo screaming on the higher rpm band.
Aug 12, 2005 - 7:27 AM
First, you have to have a turbo in the first place to put in a bigger turbo, and secondly, I wouldnt touch the engine yet you havent even finished it.
Aug 12, 2005 - 4:55 PM
TT would be sweet.. never seen it b4... but yeah make sure ebverthing works fine first
Aug 12, 2005 - 6:17 PM
Enthusiast ![]() ![]() ![]() Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) |
I'm not trying to be pessimist but it's gonna be hard to keep the twin charge setup cool. I don't think that setup is very efficient. We've done it on a couple civics, it just doesn't produce as much power is one big efficient turbo will. So, I voted for one bigger turbo, which will bring you above 300 whp.
Aug 12, 2005 - 6:36 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
QUOTE(celica3sgte @ Aug 12, 2005 - 7:17 PM) I'm not trying to be pessimist but it's gonna be hard to keep the twin charge setup cool. I don't think that setup is very efficient. We've done it on a couple civics, it just doesn't produce as much power is one big efficient turbo will. So, I voted for one bigger turbo, which will bring you above 300 whp. [right][snapback]323554[/snapback][/right] One big turbo will lag more. You could use the SC for lower RPMs and the big turbo for higher RPMs like 95ST said. -------------------- |
Aug 12, 2005 - 6:40 PM
make sure you can get it running 100% before anything, then id say do simple things liek a bov, a nnice down pipe, full exhaust if not done. Then upgrade other parts of your car, let it break in a biut more and get use to it before any crazy engine mods.
Aug 14, 2005 - 2:39 PM
Enthusiast ![]() Joined Jul 25, '05 Currently Offline Reputation: 0 (0%) |
-------------------- 1995 Celica ST - Riceball grocery getter. I saved her from Neons, 19" rims and TVs. All-stock save a weld-on muffler (does that count?) and V-AFC.
1991 CRX - The hobby car. I say that because I can never seem to get it completely together! |
Aug 14, 2005 - 7:32 PM
QUOTE([Freemantle] @ Aug 14, 2005 - 3:39 PM) [right][snapback]324041[/snapback][/right] The stock engine already has a supercharger. -------------------- |
Aug 14, 2005 - 9:00 PM
im still trying to figure out what motor he swaped in ...lol
Aug 14, 2005 - 9:38 PM
4A-GZE
| Lo-Fi Version | Time is now: September 13th, 2026 - 2:36 PM |
