> DIY - changing your transmission fluid/oil, M/T 7afe
post Aug 22, 2005 - 9:16 PM
I changed the transmission fluid/oil in my 7afe recently and Manny (presure2) took some pics - thanks Manny wink.gif
I was having some slight grinding going into 2nd gear in higher RPMs and I figured changing the tranny fluid would be a great idea. Since it has been changed, no more grinding biggrin.gif
tools needed : ratchet, 24mm socket, 3-4qts transmission fluid/oil, oil drain pan, jack/stands
time : 30min - 1hr, depending on your mechanical skill level
DO NOT attempt this when engine is hot, wait until the engine is very cool/cold.
first you need to loosen this bolt (fill plug) with a ratchet and the 24mm socket
bolt removed
it is located here, it is facing the front of the car. The transmission is circled in yellow and the arrow is pointing to the bolt location
the bolts are usually very tight and could be difficult to loosen
next, jack up the front of the car (putting it on jack stands is always safer) and with the 24mm socket you need to loosen this bolt (drain plug)
Remove drain plug. The drain plug is located directly under the transmission. You may need to remove some of the plastic under the engine for easier access. Be sure to put the oil drain pan under the bolt when removing because the old fluid/oil will be pouring out.
now after the old oil has drained out (10 min later), replace the drain plug - make sure it is secure - and lower the car.
My personal choice
Pennzoil Synchromesh
pour 3-4qrts of the Synchromesh into the fill plug hole (you might want to use a long funnel or pour/squeeze from the bottle into the hole) until full - it will start pouring back out. I used just less than 3qrts
Once full, replace fill plug - make sure it is secure - and wipe up the excess that has spilt.
Done.
Notes :
- be sure to dispose of old fluid/oil properly
- according to the BGB - 7a transmission refill = 3.5qrts, 5s transmission refill = 2.6qrts
- this procedure should be the same/similar for both 7afe and 5sfe
- Batman722   DIY - changing your transmission fluid/oil   Aug 22, 2005 - 9:16 PM
- - defgeph   Awesome work guy, I added to the sticky. Now go t...   Aug 22, 2005 - 9:44 PM
- - Silver94CelicaOwner   Awesome job you guys. I've still been too laz...   Aug 22, 2005 - 9:44 PM
- - slvrblt   To make refilling the transmission eaiser, go to a...   Nov 4, 2005 - 10:05 PM
- - TTE   Its best oil for manual transmission. I tried it o...   Nov 5, 2005 - 9:29 AM
- - blu94gt   so on the 5sfe, the fill hole is pointed slightly ...   Nov 5, 2005 - 1:12 PM
- - Supersprynt   Did you drain it first? If you open the fill hole ...   Nov 5, 2005 - 1:18 PM
|- - blu94gt   QUOTE(Supersprynt @ Nov 5, 2005 - 1:18 PM)Did...   Nov 5, 2005 - 1:20 PM
- - defgeph   Make sure you fill the tranny with all four tires ...   Nov 5, 2005 - 1:20 PM
|- - blu94gt   QUOTE(defgeph @ Nov 5, 2005 - 1:20 PM)Make su...   Nov 5, 2005 - 1:36 PM
|- - alltracman78   There are 2 reasons to have fluid come out of the ...   Aug 26, 2006 - 11:52 AM
- - Supersprynt   What I usually do is get a funnel with a tube.   Nov 5, 2005 - 1:54 PM
- - Phat_99CeliGT   i gotta do mine soon. i use Redline though. i use...   Nov 6, 2005 - 12:49 PM
- - blu94gt   I just used Coastal gear oil, it was all they had ...   Nov 6, 2005 - 7:25 PM
- - lagos   synchromesh owns all. ive been recomending it to e...   Nov 6, 2005 - 7:42 PM
- - Starcraftjunkie   I'm thinking about changing to synchromesh as ...   Nov 24, 2005 - 5:04 PM
- - trdevelopment   im gettin ready to do this also im going to use lu...   Nov 24, 2005 - 5:13 PM
- - lagos   your going to need a funnel with a long hose to do...   Nov 24, 2005 - 5:24 PM
- - Cutrara   I just did mine, and WOW! What a difference, e...   Nov 25, 2005 - 12:04 PM
- - Batman722   glad things worked out for you Alex there is a...   Nov 25, 2005 - 1:12 PM
- - Predator   damnit, seems to be much harder to change on the 3...   Nov 25, 2005 - 1:35 PM
- - Batman722   QUOTE(Predator @ Nov 25, 2005 - 1:35...   Nov 25, 2005 - 2:30 PM
- - Predator   QUOTE(Batman722 @ Nov 25, 2005 - 2:3...   Nov 25, 2005 - 3:35 PM
- - DJWashington   Nice wright up, seems to have been a big topic lat...   Nov 25, 2005 - 4:24 PM
|- - eyohannie   I tried to do it but I couldn't get that fill ...   Nov 25, 2005 - 11:07 PM
|- - blu94gt   QUOTE(eyohannie @ Nov 25, 2005 - 10...   Nov 26, 2005 - 1:04 AM
- - Cutrara   Try putting some WD-40 on there and letting it soa...   Nov 25, 2005 - 11:43 PM
|- - Batman722   QUOTE(Cutrara @ Nov 25, 2005 - 11:43...   Nov 26, 2005 - 12:05 AM
- - Batman722   QUOTE(eyohannie @ Nov 25, 2005 - 11...   Nov 26, 2005 - 1:21 AM
|- - eyohannie   hmmm... okay then, i will try it again next week a...   Nov 26, 2005 - 1:34 AM
- - lagos   use a long braker bar, and make sure you are using...   Nov 26, 2005 - 3:34 PM
- - Dunners   I changed mine yesterday with some semi synthetic ...   Nov 27, 2005 - 4:59 AM
- - Batman722   I had first changed mine and used Mobil1 synthetic...   Nov 27, 2005 - 10:40 AM
- - zipstrips   redline MTL or HD shockproof is the best tranny fl...   Nov 27, 2005 - 11:09 AM
- - Dunners   While we're on the topic, What is the differen...   Nov 28, 2005 - 1:41 AM
|- - Batman722   QUOTE(Dunners @ Nov 28, 2005 - 1:41 ...   Nov 28, 2005 - 1:45 AM
|- - Negative   QUOTE(Batman722 @ Nov 28, 2005 - 6:4...   Feb 26, 2007 - 2:58 PM
- - MaX   makes plans to do this next weekend it'll be...   May 1, 2006 - 3:11 AM
- - Jeremy1210   man, I never saw this before for some reason... I ...   May 1, 2006 - 8:12 AM
|- - blu94gt   QUOTE(Jeremy1210 @ May 1, 2006 - 8:1...   May 2, 2006 - 12:52 AM
- - Cutrara   30k? I used a cheap brand about 5k miles ago, I th...   May 2, 2006 - 7:58 PM
- - eggman40   I pour my fluid in from the top of the tranny whil...   May 2, 2006 - 8:13 PM
- - Bitter   i'd like to state one think. oils should ALWAY...   May 3, 2006 - 2:17 AM
- - DeW_H0e_GT   sorry for bring in this thread back to life..but.....   May 18, 2006 - 1:47 PM
- - pure_dx   *slaps* dew_hoe_gt you're welcome, and yes, t...   May 18, 2006 - 9:36 PM
- - Steevo   I have tried a few fluids. ATF works best from ...   Jul 24, 2006 - 8:31 PM
|- - Mynzeyes   QUOTE(Steevo @ Jul 24, 2006 - 8:31 P...   Aug 29, 2006 - 12:38 PM
- - tomazws   nice tutorial!   Jul 24, 2006 - 8:34 PM
- - Batman722   QUOTE(Steevo @ Jul 24, 2006 - 9:31 P...   Jul 24, 2006 - 9:32 PM
- - StaticKnotX   Cant get the damn fill hole off. Its chewed up a b...   Aug 28, 2006 - 7:23 PM
- - Steevo   Using a cold chisel make a indent in the side of t...   Aug 28, 2006 - 7:52 PM
- - Bitter   alot of manual transmissons use ATF as well. i kn...   Aug 29, 2006 - 1:38 PM
- - Mynzeyes   I'm about 99% that the Celica's specs call...   Aug 29, 2006 - 1:43 PM
|- - Bitter   QUOTE(Mynzeyes @ Aug 29, 2006 - 1:43...   Aug 29, 2006 - 1:46 PM
|- - Mynzeyes   QUOTE(Bitter @ Aug 29, 2006 - 1:46 P...   Aug 29, 2006 - 2:39 PM
- - Steevo   As a fact the shear stability of the ATF in use wa...   Aug 30, 2006 - 9:38 AM
- - tonytutino   man this pissed me off so much, i found the first ...   Aug 31, 2006 - 8:15 PM
|- - tomazws   QUOTE(tonytutino @ Aug 31, 2006 - 5...   Mar 5, 2007 - 12:42 PM
- - 97lestyousay   It sure is nice to get a list of tools needed for ...   Jan 6, 2007 - 3:35 PM
- - Batman722   Randy, did you change the fluid on the Celica or t...   Jan 7, 2007 - 12:28 AM
|- - 97lestyousay   QUOTE(Batman722 @ Jan 6, 2007 - 9:28...   Jan 7, 2007 - 3:28 PM
- - malecrod   Did mine today with synchromesh, pretty straightfo...   May 28, 2007 - 6:21 PM
- - 94yoter   i did mine with syncromesh today and it made a hum...   Jul 8, 2007 - 8:47 PM
- - GotToyota   I'd like to do my tranny fluid soon, as far as...   Jul 30, 2008 - 12:06 AM
- - devilsden97   QUOTE (GotToyota @ Jul 30, 2008 - 1...   Jul 30, 2008 - 11:39 AM
- - GotToyota   LOL, I know what ATF is. I just know some manual t...   Jul 30, 2008 - 11:06 PM
- - brthrurik   you can mix atf in with gear oil, that's what ...   Jul 30, 2008 - 11:18 PM
|- - Batman722   QUOTE (brthrurik @ Jul 31, 2008 - 12...   Jul 30, 2008 - 11:35 PM
- - GotToyota   I think I'm just going to buy the Royal Purple...   Jul 31, 2008 - 7:30 AM
- - devilsden97   QUOTE (GotToyota @ Jul 31, 2008 - 8...   Jul 31, 2008 - 8:42 AM
- - Bricy   Ive done mine with Synchromesh and it shifted like...   Jul 31, 2008 - 8:53 AM
|- - GotToyota   QUOTE (Bricy @ Jul 31, 2008 - 8:53 A...   Jul 31, 2008 - 9:02 AM
- - GotToyota   http://www.amsoil.com/storefront/mtf.aspx Anyone ...   Aug 3, 2008 - 5:42 PM
- - trdproven   How would you fill the ATF? My dipstick says cool...   Oct 16, 2008 - 6:34 AM
- - jordisonjr   I can't seem to find the filler bolt on my 5sf...   Jun 5, 2009 - 7:21 PM
- - Projek_01   the fillter bolt is the side facing the front of y...   Jun 5, 2009 - 7:33 PM
- - BonzaiCelica   i used some motul 75w-90. cost me $30 for 3 l...   Jun 6, 2009 - 3:27 PM
- - BonzaiCelica   bump (w/e that means) can anybody answer my questi...   Jun 17, 2009 - 5:19 PM
- - delusionz   I've been reading up about the right gearbox o...   Jun 21, 2009 - 4:52 PM
- - blu94gt   delusionz: While I've never worked on a GT-4 ...   Jun 21, 2009 - 7:31 PM
- - delusionz   Thanks alot for clearing that up for me blu94gt   Jun 21, 2009 - 8:35 PM
- - BonzaiCelica   hmm only 3sge with vvt-i has helical lsd right? a...   Jun 22, 2009 - 1:04 AM
- - ksporry   So how many liters for the 3S-GE tranny? I have to...   Jun 22, 2009 - 6:41 AM
- - delusionz   3S-GE & 5S-FE use the same transmission, albei...   Jun 22, 2009 - 5:38 PM
- - e30og   so when I change the fluid do I need to go through...   Sep 25, 2010 - 4:20 PM
- - BonzaiCelica   oh WOW! my gear were grinding when I was heel ...   Oct 27, 2010 - 3:53 AM
- - thespacepanda   Bringing this back from the dead, cuz I'm dead...   Nov 11, 2010 - 11:15 PM
Lo-Fi Version Time is now: September 13th, 2026 - 10:38 AM
