Aug 24, 2005 - 3:14 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
Im working on my car right now, and I got the 5sfe. I believe my timing belt broke because my rotor under the distrubutor cap does not spin when the motor is cranked. Is there a plug in the timing belt cover i can take off to see the belt? How do i get to it, remove the passenger wheel? What else do you recommend i change> water pump? anything else. Im still stranded since thursday!!! Thanks guys.
This post has been edited by madmods: Aug 24, 2005 - 3:32 PM |
Aug 24, 2005 - 3:25 PM
nevermind then.
This post has been edited by Supersprynt: Aug 24, 2005 - 8:57 PM -------------------- |
Aug 24, 2005 - 5:03 PM
im screwed!!! its the timing belt, and i just spent 192 on a coil some plugs and wires. Not only that, but they sent me coils for the 7 not the 5. I looked under the timing belt cover, and pulled the broken belt out a little. The relief, is at least now i know what it is.
Aug 25, 2005 - 1:06 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
can you do a how to? cuz i just bought a timing belt and want to change mine... but not sure if I can tackle it or not
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Aug 25, 2005 - 2:12 AM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
QUOTE(madmods @ Aug 25, 2005 - 12:03 AM) im screwed!!! its the timing belt, and i just spent 192 on a coil some plugs and wires. Not only that, but they sent me coils for the 7 not the 5. I looked under the timing belt cover, and pulled the broken belt out a little. The relief, is at least now i know what it is. [right][snapback]327708[/snapback][/right] I hope u didn't crank the engine with the belt off....u risk to **** valves/pistons cuz of contact between them....... |
Aug 25, 2005 - 6:55 AM
Enthusiast ![]() ![]() ![]() Joined Apr 8, '05 From Norway Currently Offline Reputation: 0 (0%) |
QUOTE(edo17982 @ Aug 25, 2005 - 2:12 AM) QUOTE(madmods @ Aug 25, 2005 - 12:03 AM) im screwed!!! its the timing belt, and i just spent 192 on a coil some plugs and wires. Not only that, but they sent me coils for the 7 not the 5. I looked under the timing belt cover, and pulled the broken belt out a little. The relief, is at least now i know what it is. [right][snapback]327708[/snapback][/right] I hope u didn't crank the engine with the belt off....u risk to **** valves/pistons cuz of contact between them....... [right][snapback]327863[/snapback][/right] To my knowledge Toyota engines are non interference engines, and does not take damage from "running" with a broken timing belt.. I don't want to bet on it though. I just remember to have heard that somewhere.. Also, our old Camry broke down when the timing belt snapped.. Nothing else got damaged.. -------------------- |
Aug 25, 2005 - 7:57 AM
Enthusiast ![]() ![]() ![]() Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) |
i dont think it damages the engine. when my all trac's timing belt snap i try to start it a couple of times and the tow truck dude tried it a couple of time and it was still fine.
Aug 25, 2005 - 8:42 AM
Hope for u it won't happen while pushing
Aug 25, 2005 - 1:24 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
Change the timing belt, water pump, pulley and tensioner to avoid any problems in that area down the line... The motor is NON-interference and no damage will be done by a broken timing belt or trying to start the car with the broke belt.
Aug 25, 2005 - 4:25 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 30, '03 From IL Currently Offline Reputation: 15 (100%) |
ooo i need to change my belt too, and a oil change...
-------------------- PROJECT 6TH GEN
![]() <FS: Things up for grabs> <Progress> |
| Lo-Fi Version | Time is now: June 28th, 2026 - 4:46 PM |
