> Lighting Info, Thought this might be helpful?
post Aug 29, 2005 - 3:35 PM
ILuvMyCelica95
Joined Dec 16, '02
Not sure where to put this confused.gif I thought it might be helpful.
1995 TOYOTA Celica
Low beam headlamp
9006
High beam headlamp
9005
Parking light
1157
194
Front turn signal
1157
Rear turn signal
1156
Tail light
1157
Stop light
1157
High mount stop light
921
Fog/Driving light
H3-55W
License plate
168
Back up light
1156
Front sidemarker
194
Rear sidemarker
1157
194
Glove box
74
Map light
293
Step/Courtesy light
194
Trunk/Cargo area
194
Instrument-general
194
Replies (1 - 19)
post Aug 29, 2005 - 6:17 PM
good idea but most of it is here
http://www.6gc.net/index.php?action=information&itu=8
there are a few you have listed which are not in the guide though
post Aug 29, 2005 - 8:24 PM
ILuvMyCelica95
Joined Dec 16, '02
hehe yeah i didnt see that
post Aug 30, 2005 - 2:36 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
If you have the JDM tails with JDM harness you will need 7440/7443 bulbs.
post Aug 30, 2005 - 7:36 PM
ILuvMyCelica95
Joined Dec 16, '02
oo i didnt think of that, and i actually needed to know that, thanks smile.gif
post Nov 29, 2005 - 2:58 PM
Nigel
Joined Aug 21, '03
From UK Liverpool
hi in the link above it says about burning out your bulb if the watts too high
High Beam - 9005 (65 watts)
Ive seen this on ebay and was going to get it.
ebay light
I was just about to buy it when it said 100watts so should i buy it?? if its better quialty light shouldnt it use more juice? right.
cheers nigel
post Nov 29, 2005 - 5:49 PM
FSX_Celica94GT
Joined Nov 26, '03
From Texas
unspoken rule of ebay - You get what you pay for
post Nov 30, 2005 - 7:14 AM
Zimluura
Joined Feb 3, '05
From USA/Virginia
also my trunk light wasn't a 194. it was some strange 1 + 1/8 inch festoon (maybe an oddity of the 99gt?).
got a 1+1/4 inch and, like everything else that hasn't quite fit, i filed it down.
post Nov 30, 2005 - 10:27 AM
ILuvMyCelica95
Joined Dec 16, '02
hmm perhaps cause i looked up a 95 celi... let's see
EDIT: nope i looked it up and it says the same.
This post has been edited by ILuvMyCelica95: Nov 30, 2005 - 10:33 AM
post Jan 28, 2006 - 7:18 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
QUOTE(WannabeGT4 @ Aug 30, 2005 - 2:36 PM) [snapback]329471[/snapback]
so which one does the turn signals use?
06 Civic EX
My For Sale Thread
post Jan 28, 2006 - 7:44 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
7440 for the turn signals if you have the JDM tail light harness. 1156 if you have the USDM harness.
post Jan 31, 2006 - 6:35 PM
yyet
Joined Jan 6, '06
From Oahu, Hawaii
Are there such things as HID or LED interior lights... that make your car like a pumpkin on halloween.
post Jan 31, 2006 - 9:31 PM
tangcla
Joined Jan 22, '06
From Melbourne, Australia
QUOTE(yyet @ Feb 1, 2006 - 10:35 AM) [snapback]387155[/snapback]
The BA9 globes which are LED won't help, as the light is being emitted perpendicular to the globe socket. Been there, done that.
And I don't think you will want HID unless you rewire your interior lights to be taken from the battery, and want to feel quite warm each time you have the light on. tongue.gif
www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS
15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2
post Jan 6, 2007 - 9:33 PM
zCelicaDude
Joined Nov 20, '06
From Auckland, New Zealand
also, for me as im in new zealand, it is easier to buy aftermarket lights via ...
Low beam bulbs: H1
High beam bulbs: HB3
Then you dont need a harness or convertor plug, as it is the same type of bulb as your factory.
i.e I have got HID Xenon 8000k installed in both my lows and my highs, and they are the same type of bulbs of my factory, so all I had to do was plug the ballast amplifier thingy straight into my factory plug... easy as that.
post Jun 22, 2007 - 3:48 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
For the record, the trunk light is not a 194. It is a wierd looking bulb. I have this type of bulb in my 95.
**** Photobucket
post Jun 22, 2007 - 4:51 PM
tangcla
Joined Jan 22, '06
Boot light is a 31mm festoon bulb.
post Jun 22, 2007 - 7:03 PM
zCelicaDude
Joined Nov 20, '06
I think the 194 led bulb will fit your park lights..
post Nov 13, 2007 - 7:29 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
Just out of curiosity (I'm fairly new to the celica modding scene), has anybody ordered and used the Xenon 9006/9005 headlights off ebay or wherever that supposedly plug straight into your factory wiring w/o modification?
Put short: should I buy these things and get a brighter beam or no?
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Nov 14, 2007 - 12:00 AM
95CelicaST
Joined Feb 5, '05
they aren't true Xenon. They are just lookalikes. They plug straight in, however I would recommend you purchase Sylvania Silverstars. Much better quality than anything you'll get from eBay.
**** Photobucket
post Nov 14, 2007 - 1:14 AM
elvasoshexai
Joined May 16, '05
QUOTE(thespacepanda @ Nov 13, 2007 - 8:29 PM) [snapback]613895[/snapback]
the wattage on those are also probably way too high and will melt ur harness... but i hear that HIR bulbs are pretty good.
This post has been edited by elvasoshexai: Nov 14, 2007 - 1:14 AM
06 Civic EX
My For Sale Thread
Lo-Fi Version Time is now: August 22nd, 2026 - 11:52 PM
