Sep 1, 2005 - 12:19 PM
Enthusiast ![]() ![]() Joined Mar 6, '05 From Fort Worth, TX Currently Offline Reputation: 0 (0%) |
Ok I have read alot of old projector posts. One post brought up the subject of wiring the turn/parking accent light in the low beam projectors, but nothing helpful.
I decided to make the light a parking light and to make the bulb amber. Coincidently, the existing side parking light plug seems like it would fit into the projector accent light plug-in(sort of). The stock turn signal plug has a plastic casing around the connector and if it is "removed" I am pretty sure it would fit. Anyways, my plan is to get a hold of that stck parking signal connector, via toyota or junkyard, cut the plastic I need to cut...etc. Is there an easier way of doing this? For instance, is their a plug I can get from Autozone/pepboys that would fit? I was close to just sotering two wires into the two metal prongs inside the accent light plug, but I thought twice. I would appreciate any direction on this. If there is a previous "helpful" post, can someone direct me to it. And I do apologize if a previous post exists, I too get a little annoyed when people do not use the search toolbar... I tried though Thanks guys/gals -------------------- ![]() |
UTSlickVic Accent light wiring in projectors Sep 1, 2005 - 12:19 PM
slipgun I sorta custom made some connectors to fit into th... Sep 1, 2005 - 7:18 PM
mark_426 I did the same thing as slipgun... I didnt have an... Sep 1, 2005 - 8:05 PM
UTSlickVic Thanks guys for your responses. I hate to say it,... Sep 1, 2005 - 10:47 PM
presure2 5th gen corner light connectors work perfectly. Sep 2, 2005 - 7:47 AM
mark_426 I took a spade connector/quick disconnect, cut it ... Sep 2, 2005 - 4:47 PM
slipgun *grins* honestly what I did was I took the connect... Sep 3, 2005 - 6:50 PM
UTSlickVic UPDATE: Went to toyota and got the answer I was e... Sep 4, 2005 - 11:41 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 26th, 2026 - 8:59 PM |
