> how do i lanch a 95 st (auto) for drag????, ^?^?^?^?^?^?^?^?^?^?^?^?^?^?^
post Sep 2, 2005 - 2:12 PM
mandrek
Joined May 4, '05
From western MD/NOVA
confused.gif yup, just about to go to the dragg stripp for the first time w/ my ST. just to have fun. but the car has 97Kmiles on it, but i don't know what i should be doing w/ the lanch.... any advice would be aprisiated. plz no flames about me not racing cuz it's an st, or that i should just get a gt or anything of that sort plz..
thank you.
mandrek
post Sep 2, 2005 - 2:14 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
its pretty rough on your tranny...but hit the brake all the way to the floor and gas it to about 2500...then let go of the brake and slam the gas? the car is probably gonna shake a lot...if its still wanting to pull forward while you're pressing the brake down hard then give it less gas. But...an auto st (no offense) isn't going anywhere fast off the line.
- Ryan
aim: rkgreen04
QUOTE(mandrek @ Sep 2, 2005 - 3:12 PM)
thank you.
mandrek
[right][snapback]330535[/snapback][/right]
step on the gas, HARD.
post Sep 2, 2005 - 2:16 PM
mandrek
Joined May 4, '05
thnx, keep em comming.
post Sep 2, 2005 - 2:33 PM
just brake hard......push the gas to the point where its reving put not moving....green just let off the brake gas to the floor
post Sep 2, 2005 - 2:35 PM
Insanity-74
Joined Jan 9, '05
From Under the car
rev the engine in neutral, when your ready to go put it into drive....dead tranny very soon but it`ll launch as good as is possible. If your just out for a laugh and dont wanna kill your car just set off like normal...with yer foot hard down, its the best your gonna get I`m affraid, Autos wernt meant for drag racing. Just sit back and enjoy the experience.
post Sep 2, 2005 - 2:47 PM
dont do any of this stuff... youll just end up with a broken tranny. the celi just isint a drag car
post Sep 2, 2005 - 2:49 PM
bonzaisushi
Joined Oct 3, '02
From bonzaisushi@hotmail.com
QUOTE(lagos @ Sep 2, 2005 - 12:47 PM)
[right][snapback]330561[/snapback][/right]
Quoted for truth
post Sep 2, 2005 - 2:54 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
If you got auto start off in gear 1 or 1, then as you go near red zone shift up to gear 2 and so on. Make sure u use the power button / over drive if you have them. Too bad gear 4 is all that car's got.
post Sep 2, 2005 - 3:32 PM
mandrek
Joined May 4, '05
thnx, yeah. i plann on haveing the od/off.
true it's not a "drag" car, but any car can still drag.... hehe
as far as "going through the gears" , i'll try that, i was thinking about doing that, but i'm not sure if this will act like the subaru auto's, they don't like it when u do that, and for some reason (even though it allows u to "hold" the gear.) ends up getting u worse times at the stripp.
as far as "pre-loading" for the launch, i'm not shure if i will do that, but we'll see..
thnx for all the advice ! ;P
post Sep 2, 2005 - 4:13 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
ok step 1 buy a mustang/vette
step 2 hit the gas.
Rjb23
Joined Feb 8, '04
From KY
Get a evo and put a tire between your rear bumper and his front bumper and when the light turns green have him step on the gas.
post Sep 2, 2005 - 4:25 PM
mandrek
Joined May 4, '05
hahahaha LOL ^^^^ that's great
post Sep 2, 2005 - 5:15 PM
celicagurl152003
Joined Oct 12, '04
From Montgomery, AL
i'll tell you now if you want to cut a good light for your rt (reaction time) your best bet is to leave when the second yellow goes on. (not the staging lighs) also i don't use me brake, i use my ebrake, but i have a 5sd....stage up and hold your ebrake up reve up to 2g and when the light gets to the second yellow (when counting down) drop the ebrake down and floor the gass......ive been doing this in copetition (elimination) for four weeks now and am running .518 rt's.......
good luck and have fun
This post has been edited by celicagurl152003: Sep 2, 2005 - 5:16 PM
post Sep 3, 2005 - 1:56 AM
mandrek
Joined May 4, '05
well, i;m back.... i chose to "slightly" pre-load the tranny, when the first yellow light on the tree whent on, (so as not to over do it, not to long) then mash on it @ the green.
and here is the result
r/t....269
60'...2.597
330..7.502
1/8...11.525
^mph 61.01
1000..14.971
1/4..17.922
^mph 211.46 (this is what the slipp says, but i have no clue as to why or what the actual 1/4 mph was......
this is w/ my home made CAI (based off the how to, but w/ only oe cut in the pipe, custom grounding kit (4awg) nology hot wire's. that's it....
do u all think that a header back set up w/ high flow cats, to an sp2 will help much?
and thnx to all who replied.
post Sep 3, 2005 - 2:48 AM
hellsyphon
Joined Dec 3, '04
From torrance, ca
QUOTE(mandrek @ Sep 3, 2005 - 1:56 AM)
r/t....269
60'...2.597
330..7.502
1/8...11.525
^mph 61.01
1000..14.971
1/4..17.922
[right][snapback]330740[/snapback][/right]
thats your 1/4(outlined in red) but the mph makes no sense lol it says your going 211.46mph and that is just a tad too fast tongue.gif
personally i think that a header with a hiflow cat wont be of much and if you want more juice out of your engine your gonna have to go the turbo or nitrious oxide route
This post has been edited by hellsyphon: Sep 3, 2005 - 2:49 AM
post Sep 3, 2005 - 6:42 PM
slipgun
Joined Jun 2, '03
From Annandale VA
what size wheels you have? Seems like most of the auto st's where high 18's so im guessing you dont have rims?
post Sep 3, 2005 - 7:37 PM
mandrek
Joined May 4, '05
high, i'm actually using my brother's stock 2000 calica GTS rims, w/ the remainder of the original tire's they'r 16" btw.....
the reason why i'm thinking about the header back set-up, is becuase when i get at the top end of my power (right when it should be really making high HP) it seems to kinda choke up... like it wants to keep going, but it's having to blow through a straw.... eh, perhaps when i get my port/ polished IM w a surgetank spacer. should help
post Sep 5, 2005 - 12:39 AM
mandrek
Joined May 4, '05
^^bump^^
post Sep 5, 2005 - 8:45 AM
slipgun
Joined Jun 2, '03
From Annandale VA
your welcome to try, Edo saved you the trouble though he fully *and I mean fully* tuned a 7afe and only produced in the low 100? Cant remember exactly. He did thousands in mods too, I would recommend a turbo at the least if you really wana see any affects.
Lo-Fi Version Time is now: August 29th, 2026 - 10:05 AM
