Sep 3, 2005 - 11:16 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 30, '03 From IL Currently Offline Reputation: 15 (100%) |
i'm too lazy to search and too lazy to go outside and look for the size of our stock wheel so i'm gonna ask you guys. our tires are 15in by ___? and the lugs are 5 by 100? whats a offset and what is it on our car? sorry for my laziness guys, please forgive me ->i'm pretty down right now.
-------------------- PROJECT 6TH GEN
![]() <FS: Things up for grabs> <Progress> |
Sep 3, 2005 - 11:52 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
-15x6.5 i believe, im too lazy to check it for sure, yes they are 5x100 even with my laziness i know this, heres an explanation of offset because im too lazy to write it offset, i dont know what the stock offset is and im to lazy to look for it, can somebody else whos not lazy feel in the holes?
-------------------- ![]() I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Sep 4, 2005 - 12:12 AM
thanks buddy. i actually found that page not too long ago. i'm probably going for some gram lights.
Sep 4, 2005 - 1:09 AM
i battled my laziness and heres what i found
stock offset is 40mm as presure2 says hereforum, i trust he knows his stuff stock wheel size is indeed 15x6.5, fitted with 205/55 tires this was cool i found while searching wheel weights -------------------- ![]() I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Sep 4, 2005 - 1:21 AM
![]() Enthusiast ![]() ![]() Joined Dec 3, '04 From torrance, ca Currently Offline Reputation: 0 (0%) |
dont want to thread jack but how wide a tire can you fit on a 6.5" rim?
Sep 4, 2005 - 2:01 AM
here, i used 1010tires.com to come up with these options. obviously the 225/50-15 is going to be the wider of the two. that is the widest tire that you will fit on a stock 15X6.5 wheel, you can fit wider tires on your celica, for example a 235/40-17 (a few celicas on this site have this site without apparent trouble) but this, of course, will require a 17x8 wheel. i know from experience that a 225/50 will cause no rubbing problems whatsoever. my brother has this size on his 90 celi gts.
![]() if you are looking to buy tires, toyo proxes 4's perform and look nice (my bro) as well al falken ziex ze512's which i have, both are all-season tires which i recommend for you since you live in canada proxes 4 ![]() ziex ze512, these are decently priced and were rated #1 by consumers digest a while back i believe
Sep 4, 2005 - 2:04 PM
THANK YOU THANK YOU THANK YOU. Its great that somebody still replies on question i ask.
Sep 6, 2005 - 6:46 PM
There 15x7 ... at least thats what mine are.
Sep 6, 2005 - 8:48 PM
QUOTE(Digndoug @ Sep 6, 2005 - 6:46 PM) There 15x7 ... at least thats what mine are. [right][snapback]331515[/snapback][/right] correct. This post has been edited by jgreening: Sep 6, 2005 - 8:48 PM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
| Lo-Fi Version | Time is now: August 26th, 2026 - 4:36 AM |
