Sep 8, 2005 - 8:17 PM
Enthusiast Joined Sep 8, '05 Currently Offline Reputation: 0 (0%) |
Hi. I need to change back to my old stock steering wheel since it failed the DMV inspection. I have a Momo steering wheel. I know I can remove the rubber on the front and expose small allen type screws.. How do I replace it. Is it by removing those allen screws will remove the cover(?) and expose the nut to remove the whole steering wheel? Thanks.
Sep 8, 2005 - 8:28 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
after you take off all the screws, you will be left with one big nut at the middle of the steering colum. You need a press tool to help pull the wheel off the car.
after that just re-install your other steering wheel. |
Sep 8, 2005 - 8:51 PM
If I don't have a press tool, can I still take it out manually? Is a press tool like a "puller"? Thank you.
Sep 8, 2005 - 9:04 PM
press and puller tool is the same thing. You can try to remove it with out the tool. But i would be alot harder.
Sep 8, 2005 - 9:12 PM
I do believe that aftermarket hubs usually aren't pressed on very tight. Once you remove the nut, the hub may remove without a puller.
| Lo-Fi Version | Time is now: August 28th, 2026 - 7:47 AM |
