> celica runing too rich!!!
post Sep 14, 2005 - 8:19 PM
st_celica_killer
Joined Sep 23, '04
From fresno
how do you fix a car runing pig rich??? car runs too rich at high rpm !!!! with tons of my black smokes coming out!! so help frown.gif frown.gif
This post has been edited by st_celica_killer: Sep 14, 2005 - 8:20 PM
post Sep 14, 2005 - 8:20 PM
How do your spark plugs look? Mine are coated in carbon...I need to order new ones soon because I get black clouds too. tongue.gif
st_celica_killer
Joined Sep 23, '04
From fresno
i just replaced them with NGK... and i still dont notices why there is still black smoke
post Sep 14, 2005 - 8:44 PM
QUOTE(st_celica_killer @ Sep 14, 2005 - 9:20 PM)
[right][snapback]334278[/snapback][/right]
prolly your 02 sensor going bad. notice bad gas mileage? check engine lights?
post Sep 14, 2005 - 9:06 PM
st_celica_killer
Joined Sep 23, '04
From fresno
well there is no sign of check engine light....!!! well yeah i do notices a little bad gas mileage thoug! other then that the car still runs fine..
post Sep 15, 2005 - 12:40 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I would check the O2 sensor
**** Photobucket
post Sep 15, 2005 - 10:57 AM
Craig
Joined Sep 2, '05
From England, Uk
with the gt4's they run rich as hell m8 im all ways getting black smoke out the ass end when im flooring it ive checked the o2 sensor but its fine so guess im going have to put up with cleaing the rear end of the car every week cause of the black soot that she kicks out.
craig
post Sep 15, 2005 - 11:13 AM
QUOTE(Craig @ Sep 15, 2005 - 11:57 AM)
craig
[right][snapback]334496[/snapback][/right]
yea, craig, the gt-4 natrally runs rich from the factory, the N/A usdm celicas however, arnt under normal conditions wink.gif
post Sep 15, 2005 - 11:17 AM
Kadett
Joined Mar 17, '05
From The Netherlands
How can you check if the O2 sensor still works. Putting a Multimeter on it?
Because i always have bad Milage. Even when driving 70 mph straight on the freeway. Always 18-20 mpg!
post Sep 15, 2005 - 11:27 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Hey I noticed that my JDM engine gives off a bang when I rev it really high(8K) and let go of the throttle cable. Is this common in you JDM engin confused.gif es as well?
post Sep 15, 2005 - 11:30 AM
QUOTE(Kadett @ Sep 15, 2005 - 11:17 AM)
[right][snapback]334503[/snapback][/right]
yes. check the BGB on celicatech.com to find out how to test it
you can also use those cheap a/f gauges to tell you how your o2 sensor is working.
post Sep 15, 2005 - 12:43 PM
st_celica_killer
Joined Sep 23, '04
From fresno
well i did check out the o2 sensor plus i have a/f gauge also..which everything is running fine..but the car just smokes alot at high rpm...it just makes no sense at alll!!!!!
This post has been edited by st_celica_killer: Sep 15, 2005 - 12:43 PM
Lo-Fi Version Time is now: August 28th, 2026 - 6:40 AM
