> need help wheel bearing
post Sep 20, 2005 - 9:45 PM
latinomasfino
Joined Feb 17, '04
ok so now i have to replace my front driver wheel bearing umm its different than the rear one i had to replace beucase the front is not bolt on has anyone done it yet? is it hard any tips i heard u have to press it how does that work???
Replies (1 - 5)
post Sep 20, 2005 - 10:03 PM
I hear you have to take the hub out to a shop and get it pressed out or something. I just replaced mine last weekend, but thankfully everything was in good shape on my parts car, and I just swapped the whole knuckle/bearing/hub in.
post Sep 20, 2005 - 10:47 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Yeah, you need a press. It's not hard to do, but you have to use one to get it apart.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Sep 21, 2005 - 12:26 AM
latinomasfino
Joined Feb 17, '04
hmm do u think they have a press at a local midas?
post Sep 21, 2005 - 3:27 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
You will need to take the hub in somewhere and have the old bearing pressed out, and the new one pressed in. Make sure you torque the axle nut to specifications (166 ft-lbs according to my .pdf manual) or you'll have trouble. Also a good time to replace the ball joints if yours are no good.
post Sep 26, 2005 - 9:50 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I have to do the same thing, But i thought you could just get the tools from autozone, the free renting thing? any one know off hand?
Lo-Fi Version Time is now: August 21st, 2026 - 11:37 PM
