Sep 20, 2005 - 11:55 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
i was thinking gettin a faze water temperatue n air furl ratio gauge...any ideas u guys thik its beneficial to optimizin the motor?
Sep 21, 2005 - 12:15 AM
QUOTE(DeW_H0e_GT @ Sep 20, 2005 - 11:55 PM) i was thinking gettin a faze water temperatue n air furl ratio gauge...any ideas u guys thik its beneficial to optimizin the motor? [right][snapback]336803[/snapback][/right] No. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Sep 21, 2005 - 12:47 AM
lol Jay
maybe an oil presure or an oil temp gauge -------------------- |
Sep 21, 2005 - 1:59 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Seattle, WA Currently Offline Reputation: 0 (0%) |
yeah, the afr gauge is a waste. Coolant temp might be nice if you drive long distance a lot, or if you get stuck in traffic in the sun all the time. Volt meter if you have a lot of electronic goodies. Otherwise, oil temp and pressure.
-------------------- Its Orville's Celica, i just drive it... |
Sep 21, 2005 - 9:57 PM
thanx guys
Sep 22, 2005 - 5:59 AM
on our engines, stock, there is NO need for either of those gauges.
Oct 6, 2005 - 11:19 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
I object AFR is pretty good considering how I ditched my cruise control.
Oct 6, 2005 - 12:59 PM
QUOTE(soulshadow @ Oct 6, 2005 - 11:19 AM) I object AFR is pretty good considering how I ditched my cruise control. [right][snapback]341731[/snapback][/right] the afr gauge dosnt tell you anything about how much fuel or air your car is using. the only thing its good for, it to be able to see that your O2 sensor is working and if your car goes into closed loop mode. thats it.... oh and its a cool light show. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Oct 6, 2005 - 9:39 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Yea unless its a wideband O2 meter than its not going to do much. And the only time you really need gauges is if you change the stock tunings of a motor and need to keep tabs of the saftey and performance of your engine, or if you just happen to dig gauges ragardless of their purpose.
-------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Oct 9, 2005 - 10:33 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
again, no reason to if your engine is stock. but if you do, id install them in the pocket like jgreening or doggy has, looks nice in my opinion. by the way, that has to be the biggest wing i have ever seen on a car...
-------------------- ![]() I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Oct 9, 2005 - 11:12 PM
Ya like mine?
Engine aint so special and its running on stock ECU! but, you know these things attract a lot of attention. I've had an Suv, SI, focus, and truck trying to race me as I drove down the freeway at night. ![]() |
Oct 9, 2005 - 11:48 PM
looks hot!!!!!...what are those guages?.....cant really see it....i can see the first...a afr, second temp gauge....whats the third?..easy to install?
Oct 10, 2005 - 9:33 AM
QUOTE(DeW_H0e_GT @ Oct 9, 2005 - 11:48 PM) looks hot!!!!!...what are those guages?.....cant really see it....i can see the first...a afr, second temp gauge....whats the third?..easy to install? [right][snapback]342900[/snapback][/right] The third one is an Oil temp, but because I don't want to drill into the oil pan its not connected, cause I don't think I can find a JDM oilpan in america...... I'm gonna replace it with an oil pressure gauge. Its pretty hard to see in daylight, but at night...WOW!! These are very easy to install, you just have to pull your trims off, splice the wires to the ECU and Viola!! I did however cut a hole into the side trims to put on the pillars. All you need is a scredriver to pry off things, a blade to cut things and your Trusty Dremel! |
Oct 11, 2005 - 10:53 AM
thanks for the response...i think i kno what to put in the dual gauge pod now....i think a afr and a oil pressure is fine..and i work at advance discount so i kno for a fact they have an oil pan for a gt not sure about the ST.....unless u have a 3sgte swap..then i might agree wit u buddy..=D
Oct 11, 2005 - 1:13 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
QUOTE(soulshadow @ Oct 10, 2005 - 7:33 AM) QUOTE(DeW_H0e_GT @ Oct 9, 2005 - 11:48 PM) looks hot!!!!!...what are those guages?.....cant really see it....i can see the first...a afr, second temp gauge....whats the third?..easy to install? [right][snapback]342900[/snapback][/right] The third one is an Oil temp, but because I don't want to drill into the oil pan its not connected, cause I don't think I can find a JDM oilpan in america...... I'm gonna replace it with an oil pressure gauge. Its pretty hard to see in daylight, but at night...WOW!! These are very easy to install, you just have to pull your trims off, splice the wires to the ECU and Viola!! I did however cut a hole into the side trims to put on the pillars. All you need is a scredriver to pry off things, a blade to cut things and your Trusty Dremel! [right][snapback]342970[/snapback][/right] just "T" off your knock sensor and screw in your sending unit thats what i did for my oil temp and pressure -------------------- yea your 3sgte is cool but ill stick to my 7agte
Nov 3, 2005 - 11:54 PM
maybe im too dumb to be a mechanic..BUT can ne1 explain to me how to install an oil pressure & afr guage?
Nov 4, 2005 - 11:20 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
QUOTE(soulshadow @ Oct 10, 2005 - 4:12 AM) Ya like mine? Engine aint so special and its running on stock ECU! but, you know these things attract a lot of attention. I've had an Suv, SI, focus, and truck trying to race me as I drove down the freeway at night. ![]() [right][snapback]342880[/snapback][/right] Actually that particular AFR gauge is very handy. It responds pretty well and I trust it as far as the stock 02 sensor goes. Most AFR gauges are just light shows though. BTW - Autozone has a generic dual A Pillar gauge pod that works really well in our cars. -------------------- ![]() |
Mar 18, 2007 - 7:50 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I just got my MKIV Supra Gauge Pod in and so I'll be moving my gauges to that.. anyone know which wires on the A-Pillar are for Constant Power, Ignition, & Headlights? How did you all run the wires?
I was looking but couldn't find a how to... Thanks! -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Mar 18, 2007 - 10:54 PM
i ran the wires thru teh firewall which was preciously drilled by last owner.......
as for the wires i ahve no clue sorry......but u can tap into the ignition switch for 12v power..... -------------------- ![]() |
Apr 15, 2007 - 1:10 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
QUOTE(Jaws4God @ Mar 18, 2007 - 5:50 PM) [snapback]537393[/snapback] I just got my MKIV Supra Gauge Pod in and so I'll be moving my gauges to that.. anyone know which wires on the A-Pillar are for Constant Power, Ignition, & Headlights? How did you all run the wires? I was looking but couldn't find a how to... Thanks! bump! -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
| Lo-Fi Version | Time is now: September 3rd, 2026 - 9:23 PM |
