Sep 21, 2005 - 2:05 PM
Enthusiast ![]() Joined Dec 2, '03 From Virginia Currently Offline Reputation: 0 (0%) |
I can't figure out how to remove this gear, the chilton's and service manual just says use a puller. I have a 2 arm puller but the arms can't fit behind the rear sproket, and it seems like if it could it would bend it. Any suggestions?
Snarfer crankshaft timing gear Sep 21, 2005 - 2:05 PM
gamesteristj I thought it showed using two screwdrivers on eith... Sep 21, 2005 - 5:32 PM
FallenHero I used a large flat screwdriver. Wedged it in the... Sep 21, 2005 - 5:43 PM
Snarfer ok cool i was just worried about messing it up, th... Sep 21, 2005 - 11:00 PM
FallenHero it's cast iron... you're not going to mess... Sep 22, 2005 - 2:02 AM
ice23q you need to use two large screwdrivers ....one on ... Oct 3, 2005 - 3:07 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 24th, 2026 - 6:45 PM |
