Sep 21, 2005 - 3:28 PM
What do you guys use to pull a 7A-FE? There's one hook near the throttle body, but there's not one on the front of the block. I'm just wondering what you guys have used to pull the engine.
Sep 21, 2005 - 4:12 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
you can use the coolant neck near the front or just a bolt from the exhaust manifold, ive done that on a couple honda swap i did.
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Sep 21, 2005 - 4:13 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
hook up to the alt. bracket.
DEF -------------------- ![]() I will return one day. |
Sep 21, 2005 - 4:33 PM
Alright, thanks for the help guys.
Sep 21, 2005 - 4:36 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
DO NOT hook a chain up to the coolant neck!
You can use either the alternator bracket, or just grab a hook off another engine and bolt it in there, there is a place for it. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Sep 21, 2005 - 4:53 PM
QUOTE(Dr_Tweak @ Sep 21, 2005 - 4:36 PM) DO NOT hook a chain up to the coolant neck! You can use either the alternator bracket, or just grab a hook off another engine and bolt it in there, there is a place for it. -Doc [right][snapback]337061[/snapback][/right] lol that response took longer than i had guessed, i use it if im lazy and im just pulling out the old motor i dont care about nemore. so im guessing your taking the parts ST apart coomer? -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Sep 21, 2005 - 5:11 PM
lol i ran my chain under the intake manifold i had no hooks
Sep 21, 2005 - 5:31 PM
Enthusiast ![]() Joined Feb 18, '04 From Spokane Washington Currently Offline Reputation: 0 (0%) |
I ran a rope around the front (pulley side) engine mount to the hook so that I could swing it easier. But I don't know...
tj |
Sep 21, 2005 - 7:14 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
get urself an engine hoist and use the hole at the end of one of the hoist and attach a bolt through it than bolt that on to the front of the engine on the top left.
Sep 21, 2005 - 7:50 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
I just used the studs from the exhaust manifold.
-------------------- AIM : FAQdaWorld
| Lo-Fi Version | Time is now: August 24th, 2026 - 7:28 AM |
