Sep 25, 2005 - 1:59 PM
Enthusiast ![]() ![]() ![]() Joined Jan 24, '05 From toronto,ontario canada Currently Offline Reputation: 0 (0%) |
I have a power supply that doesnt show how many watts it has, , in voltage though it says 115/230 12v does anyone know what that would be in watts?
-------------------- Go leafs go
Sep 25, 2005 - 4:56 PM
Enthusiast ![]() ![]() Joined Mar 2, '04 From Louisiana, USA Currently Offline Reputation: 2 (100%) |
Those are just the input voltages the PS can accept. Not enough information to determine the wattage of the unit. If you're not sure if you will have enough power to your rig, just buy a decent quality PS with enough capacity for you.
Sep 25, 2005 - 6:11 PM
![]() Enthusiast ![]() ![]() Joined Apr 23, '04 From WA Currently Offline Reputation: 3 (100%) |
usuallyon the sticker on the ps tells you how many watts
some dont say but have it in there part numbers. |
Sep 25, 2005 - 6:32 PM
plug it in and try it out... if the system crashes under heavy gaming, youll know its not enough
Sep 25, 2005 - 6:34 PM
make sure you check your voltages because you dont wanna be giving your computer dirty power.
for example 12+ should be between 11.500 to 12.500 12- should be between -11.500 to -12.500 5+ should be between 4.500 to 5.500 5- should be between -4.500 to -5.500 |
Sep 26, 2005 - 2:04 PM
Just found out what i have, but thanks anyways guys, reason for asking is cuz i got a killer video card and i was wondering if my power supply could handle it.
Sep 26, 2005 - 2:10 PM
so what was it? what vid card did u get?
Sep 26, 2005 - 7:59 PM
I got the nVidia 6800xt
Sep 28, 2005 - 10:09 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Charlotte Currently Offline Reputation: 0 (0%) |
A 400watt would be more than enough but most standard supplies today are 450watt.
Sep 28, 2005 - 10:57 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
Power = Current * Voltage
hook a voltmeter two the + and - prong of it in current mode...make sure you have it on the highest setting and work down. -------------------- ![]() |
Sep 29, 2005 - 11:20 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
If it does not say how much it is then I would assume its not a good PS (power supply,) brand wise. just get a new one off the net there pretty cheap rather then messing with an junky one.
| Lo-Fi Version | Time is now: June 12th, 2026 - 3:47 AM |
