> auto to stick
post Dec 12, 2002 - 9:44 PM
gregsju29
Joined Oct 30, '02
From CT
hey i have a 94 st, and sadly it's automatic....is it easy to make it stick,,and if so how????
Replies (1 - 14)
post Dec 13, 2002 - 11:54 AM
TrDcElica6thgen
Joined Nov 18, '02
From Belmont, CA
i remember my friends prelude was an auto and he changed it for about 7k i think? all try to ask him how and where he did it for u.
post Dec 13, 2002 - 12:09 PM
Dazed128
Joined Nov 12, '02
From CT
Ok, I did this conversion this summer to my 94 ST. It was fairly straight forward and cost me 800 in parts beucause I did the labor myself. This is what you will need:
c-52 manual tranny 94-99 st
Slave Cylinder
Hydraulic Lines
Master Cylinder
Clutch (Disc, pressure plate, throw out bearing)
Manual Flywheel
Clutch Pedal
Brake Pedal off manual celica
Shifter
Shift boot
Shift cables
ALL Engine mounts for manual
ALL bolts needed...flywheel uses different bolts, need pedal bolts, clutch bolts, bolts for tranny, etc..
The swap took me 15 hours with the help of a friend. It should have been faster but we ran into some snags. This is a really rough outline of the swap but here ya go: Remove Front wheels, lower left and right control arms, remove axles from wheel hub, pull axles off of tranny, place jack under tranny, remove all hoses wires etc, remove all bolts holding tranny to engine (remove starter), slowly pull tranny out and away while dropping it with jack, remove torque converter and flywheel, replace with manual flywheel, use clutch guide tool and insert clutch, bolt pressure plate over clutch assembly, raise manual tranny and bolt on with necessary bolts. Now cut a whole in firewall where the clutch master cylinder would go, bolt onto clutch pedal, connect hydraulic lines from slave cylinder on tranny to the master cylinder. Attach brake pedal, shifter, attach shifter cables from shifter to control levers on tranny. On the automatic tranny there is the neutral safety switch, in order for the ecu to bypass this you need to splice two wires together to bypass the neutral safetery switch to make the car believe it is manual. Start her up and pray everythings all right. Thats really really rough but you get the idea
post Dec 13, 2002 - 6:04 PM
dayzdchika
Joined Oct 6, '02
From currently @ UMD
QUOTE (Dazed128 @ Dec 13 2002, 12:09 PM)
Ok, I did this conversion this summer to my 94 ST.....
post Dec 14, 2002 - 6:18 PM
macavely
Joined Nov 4, '02
Thanks for the info Dazed I'm going to see if i can find somewhere, where i can swap my auto for a manuel trans.
post Dec 14, 2002 - 9:34 PM
gregsju29
Joined Oct 30, '02
From CT
hey Dazed, i hit u with an email.thanks
post Dec 15, 2002 - 12:48 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
I think your friend got ****ed!!!
post Dec 16, 2002 - 2:17 AM
macavely
Joined Nov 4, '02
Can i get some names of web site where i can look for price on tansmissions and the other parts need to do this swap.
post Dec 16, 2002 - 2:21 AM
QUOTE (macavely @ Dec 16 2002, 12:17 AM)
You could contact http://www.usedengines.com and see if they have a used tranny for your car.
post Dec 18, 2002 - 4:25 AM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
Or you could by all the parts from me.
Email me for more info: rayf@illmaticonline.com
-Ray
post Dec 20, 2002 - 12:05 PM
Paethon
Joined Dec 19, '02
From New Hampshire
I want my 5 speed to be a 6............ 20 grand a year for college x 6 years.... or 120k worth of mods... wink.gif
post Dec 20, 2002 - 9:34 PM
macavely
Joined Nov 4, '02
QUOTE (Paethon @ Dec 20 2002, 12:05 PM)
damn man hard choice
post Dec 22, 2002 - 10:36 AM
Paethon
Joined Dec 19, '02
From New Hampshire
i think i'll stick with the degree ...
post Dec 25, 2002 - 9:03 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
120k piece of paper or one BAD ASS RIDE....... thats a easy choice!!! biggrin.gif
post Dec 27, 2002 - 1:41 PM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
QUOTE (Dazed128 @ Dec 13 2002, 10:09 AM)
Slave Cylinder
Hydraulic Lines
Master Cylinder
Manual Flywheel
Clutch Pedal
Shifter
Shift boot
Shift cables
thanks dude I've looking 4 dat in celica.net
Lo-Fi Version Time is now: May 20th, 2026 - 4:10 PM
