Sep 27, 2005 - 9:52 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 25, '03 From Miami, FL Currently Offline Reputation: 9 (100%) |
I was just wondering how the fuel gauge works on the clusterr. See I have an st205 cluster now and the fuel wont display. it tells me when im about to run out by lighting up the orange fuel light. but thats about it. the needle stays on empty. anyway to reset this or something? thanks.
Sep 27, 2005 - 10:42 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
maybe with all these problems you're having with that cluster you should put your stock one back??
Sep 27, 2005 - 2:58 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
AT200 and ST205 fuel level sending units function the same. Resistance on each is 3 ohms Full to 110 ohms Empty.
There are at least two different pinouts for the ST205 combo meter plugs. The major difference I see in the two schematics is the addition of the rear fog lights for the European models so it's probably safe to say the JDM ST205 will more than likely be identical to the Australian ST205. Also, some of the pins on plugs B and C are different as well. According to Toyota BGBs at Celicatech AT200 Combo Meter Plugs: A: 13 pin B: 16 pin C: 10 pin ST205 Combo Meter Plugs: A: 16 pin B: 10 pin C: 13 pin For Australian ST205 Combo Meter: Fuel Gauge AT200---ST205 B14---to---B1 B6----to---A7 Low Fuel Light AT200---ST205 C6---to---B6 For European ST205 Combo Meter: Fuel Gauge AT200---ST205 B14---to---B2 B6----to---A7 Low Fuel Light AT200---ST205 C6---to---B7 Also, in order to run your boost gauge you'll need to run a MAP sensor from an ST205 soley for the new guage cluster. This post has been edited by WannabeGT4: Sep 27, 2005 - 3:45 PM -------------------- ![]() Project ST204.5 99.88946% complete... |
Sep 27, 2005 - 3:20 PM
Wannabe. Thanks for all that info. However, I'm not very electronically inclined so I don't really know what any of that means. I hooked everything up how purplegt4 said and everything shoulda worked fine. But what does all that mean? Waht would I need to change to make the Fuel Gauge work? Thanks. By combo meter, I'm guessing you mean the temperature gauge? Because that would make sense since that one doesn't read correctly either. Thanks.
Sep 27, 2005 - 3:36 PM
Combonation Meter is what is commonly refered to as the "cluster". As for the information I posted I'll try and explain what you need to do:
Example: AT200---ST205 B14---to---B1 B6----to---A7 The AT200's wire 14 in Plug B needs to be connected to the ST205's wire 1 in Plug B. The AT200's wire 6 in Plug B needs to be connected to the ST205s wire 7 in Plug A . Remember that we are using the plug labels A, B, and C just like they appear in the BGB: AT200 Combo Meter Plugs: A: 13 pin B: 16 pin C: 10 pin ST205 Combo Meter Plugs: A: 16 pin B: 10 pin C: 13 pin More than likely your water temperature gauge is connected wrong as well. Try this: For Australian ST205 Combo Meter: Water Temp Gauge AT200---ST205 C2---to---B3 C4---to---B2 For European ST205 Combo Meter: Water Temp Gauge AT200---ST205 C2---to---B3 C4---to---B5 I might be able to help a little better if you told me exactly what you've done so far and what you're working with. Do you have the plugs that go to the ST205 Combo Meter? Where is the Combo Meter from Japan, Europe, Ausralia..? What information has PurpleGT4 supplied you with? Have you downloaded the EWDs for the ST205 and the AT200/ST204 from celicatech? This post has been edited by WannabeGT4: Sep 28, 2005 - 9:31 AM -------------------- ![]() Project ST204.5 99.88946% complete... |
Sep 27, 2005 - 3:42 PM
![]() Australian ST205 Combo Meter:
Sep 27, 2005 - 5:14 PM
Yes Wannabe, I do have the original plugs and about a foot of wiring that was cut from the ST205 harness. I cut the plugs from the AT200 harness right at the plug and connected the wires to the ST205 harness. The information that purplegt4 sent was this:
Connector "A" ST205 AT200 A1-A1 A2-A2 A3-A4 A4 A5 A6-A6 A7-A7 A8-A8 A9-A9 A10-A10 A11-A11 A12 A13-C6 A14-A14 A15 A16-A16 Connector "B" ST205 AT200 B1 B2 B3-B5 B4-3-9 B5 1-4 B6 B7-B7 B8-B9 B9-A3 B10 Connector "C" ST205 AT200 C1-A13 C2-C7 C6-C6 C8-C4 C10-C8 C11-C11 C13-C13 My ComboMeter was purchased from k_trac in Mass. He says the cluster is from Japan because it came with a front clip that had a ceramic turbo and that only the one's in Japan came with that. I haven't downloaded the EWD because I don't understand those diagrams. Lol. I thought it was easier than it was. You must know a lot about elctronics because yes, my temp gauge doesn't work either. Lol. It would be awesome if you could tell me exactlyhow to hook this up so that everything works properly. EDIT: I have an AT200 Automatic Transmission. I dont' know if that makes a difference... This post has been edited by JoKeRkId613: Sep 27, 2005 - 8:58 PM -------------------- ![]() |
Sep 28, 2005 - 3:29 PM
bump
Sep 28, 2005 - 4:32 PM
Sorry, no time to work on it lately. I'll try and work on it tonight. Most of what you need is already posted though.
Sep 28, 2005 - 5:23 PM
Hey bro, take your time. I'm glad to hear I pretty much got everything correct already since I already put everything back together and taped everything off. Lol. But that's cool. I just want you to know that I appreciate what you're doing for me man. Thanks again and I can't wait to have this project done so I can see how much fuel I have left. Hehe.
Sep 29, 2005 - 2:50 PM
For the sake of simplicity, from here on out, both AT200 and ST205 connectors will use this scheme (as per USDM BGB):
A = 13 pin B = 16 pin C = 10 pin Wires in the column labeled ST204/AT200 will need to be connected to the plug in the column labeled ST205. Australia ST204 AT200---ST205 A01---to---A02 A02---to---A01 A03---to---?NO SRS LIGHT? A04---to---?NO SRS LIGHT? A05---to---?NO SEATBELT LIGHT? A06---to---B03 A07---to---B05 A08---to---A04 A09---to---B06 A10---to---A09 A11---to---N/A A12---to---N/A A13---to---?PARK, NEUTRAL, CLUTCH SWITCH? B01---to---B01 B02---to---N/A B03---to---B02 B04---to---A12 B05---to---N/A B06---to---B07 B07---to---B08 B08---to---B09 B09---to---B10 B10---to---B11 B11---to---B12 B12---to---N/A B13---to---B14 B14---to---C01 B15---to---B15 B16---to---B16 C01---to---N/A C02---to---C03 C03---to---N/A C04---to---C02 C05---to---N/A C06---to---C06 C07---to---C07 C08---to---C08 C09---to---C09 C10---to---C10 Europe ST204 AT200---ST205 A01---to---A02 A02---to---A01 A03---to---?NO SRS LIGHT? A04---to---?NO SRS LIGHT? A05---to---?NO SEATBELT LIGHT? A06---to---B03 A07---to---B05 A08---to---A04 A09---to---B06 A10---to---A09 A11---to---N/A A12---to---N/A A13---to---?PARK, NEUTRAL, CLUTCH SWITCH? B01---to---B01 B02---to---N/A B03---to---B02 B04---to---A12 B05---to---N/A B06---to---B07 B07---to---B08 B08---to---B09 B09---to---B10 B10---to---B11 B11---to---B12 B12---to---N/A B13---to---B14 B14---to---C02 B15---to---B15 B16---to---B16 C01---to---N/A C02---to---C03 C03---to---N/A C04---to---C05 C05---to---N/A C06---to---C07 C07---to---C08 C08---to---?NO O/D OFF LIGHT? C09---to---?NO CRUISE CONTROL LIGHT? C10---to---C10 Does the ST205 combo meter not have a warning light for the seatbelt or airbags? Aparently the European ST205 doesn't have seatbelt, airbag, O/D off, or cruise control lights. EDIT: 10/22/2005 Before i give the pin information I'm going to make sure a few things are known: 1. You will not have a cruise control indicator. 2. You will not have an overdrive off indicator. 3. Wire A13 from the AT200 will not plug into anything which simply means your brake light won't come on when you're starting the car. 4. Rear foglights indicator will not be used for obvious reasons. 5. I have no idea what the indicator is below the rear foglight indicator and therefore will not be used. 6. There are diodes in the rear foglight and mystery indicator circuits. You don't need to worry about them. No need to put bulbs in their sockets either. 7. B13 on the ST205 combo meter will be directly connected to the MAP sensor from an ST205. Japan ST204 AT200---ST205 A01---to---A01 A02---to---B02 A03---to---C05 A04---to---C04 A05---to---C07 A06---to---A04 A07---to---A12 A08---to---A08 A09---to---B04 A10---to---A06 A11---to---NOTHING A12---to---NOTHING A13---to---N/A (BRAKE LIGHT ON WHILE STARTING) B01---to---B01 B02---to---NOTHING B03---to---B03 B04---to---A13 B05---to---NOTHING B06---to---B06 B07---to---B07 B08---to---B08 B09---to---B09 B10---to---B10 B11---to---B11 B12---to---NOTHING B13---to---B14 B14---to---C01 B15---to---B15 B16---to---B16 C01---to---NOTHING C02---to---C02 C03---to---NOTHING C04---to---C03 C05---to---NOTHING C06---to---C08 C07---to---C06 C08---to---N/A (OVERDRIVE) C09---to---N/A (CRUISE) C10---to---C10 This post has been edited by WannabeGT4: Oct 23, 2005 - 9:06 AM -------------------- ![]() Project ST204.5 99.88946% complete... |
Sep 29, 2005 - 4:43 PM
Thanks a lot Wannabe. I'll compare those to mine and make the appropriate changes as soon as I get home. I know for a fact that the ST205 has the seatbelt light, in fact, I got it working today(My "Dome" fuse under the hood was blown and my dome light, door open light, and seatbelt light didn't work.) But I'll doublecheck on the airbag light. I'm pretty sure it does have one. But for sure it does have a seatbelt warning light. I'm guessing the Australian ST205 is the same as the Japanese ST205? Is that what you meant there? Thanks again, Wannabe.
EDIT: Wait, that doesn't make any sense... On the previous post, you said this: For Australian ST205 Combo Meter Water Temp Gauge AT200---ST205 C02---to---B03 C04---to---B02 WHICH TRANSLATES IN USDM PLUGS TO: For Australian ST205 Combo Meter: Water Temp Gauge AT200---ST205 C02---to---C03 C04---to---C02 ***SORRY, I GOT IT NOW*** Lol. I'm kinda slow when it comes to these things... This post has been edited by JoKeRkId613: Sep 29, 2005 - 6:06 PM -------------------- ![]() |
Sep 29, 2005 - 5:08 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 16, '03 Currently Offline Reputation: 1 (100%) |
i say fill it up at the station, take the needle out and put it on Full.. u shoukld be good after that. i took mine off and put it back wrong, now when im on full it says im on half
Sep 29, 2005 - 5:44 PM
^Will that really work???
EDIT: Nah, Charles, it still won't work. "Full" will just become the "dead point" for the fuel gauge because according to Wannabe's connections, my fuel gauge and temp gauge aren't even hooked up. Lol. Which makes sense. Thanks for the suggestion tho. Anyway. I converted what I had done with the wiring to what Wannabe gave me. So this is what he did: AT200---ST205 A01---to---A02 A02---to---A01 A03---to---?NO SRS LIGHT? A04---to---?NO SRS LIGHT? A05---to---?NO SEATBELT LIGHT? A06---to---B03 A07---to---B05 A08---to---A04 A09---to---B06 A10---to---A09 A11---to---N/A A12---to---N/A A13---to---?PARK, NEUTRAL, CLUTCH SWITCH? B01---to---B01 B02---to---N/A B03---to---B02 B04---to---A12 B05---to---N/A B06---to---B07 B07---to---B08 B08---to---B09 B09---to---B10 B10---to---B11 B11---to---B12 B12---to---N/A B13---to---B14 B14---to---C01 B15---to---B15 B16---to---B16 C01---to---N/A C02---to---C03 C03---to---N/A C04---to---C02 C05---to---N/A C06---to---C06 C07---to---C07 C08---to---C08 C09---to---C09 C10---to---C10 And this is what I did: AT200---ST205 A01---to---N/A A02---to---N/A A03---to---N/A A04---to---A08 A05---to---N/A A06---to---A06 A07---to---A02 A08---to---A10 A09---to---C04 A10---to---N/A A11---to---A11 A12---to---N/A A13---to---A13 B01---to---B01 B02---to---B02 B03---to---C09 B04---to---B03 B05---to---N/A B06---to---B06 B07---to---B07 B08---to---B08 B09---to---B09 B10---to---B10 B11---to---B11 B12---to---N/A B13---to---A01 B14---to---B14 B15---to---N/A B16---to---B16 C01---to---N/A C02---to---N/A C03---to---N/A C04---to---C05 C05---to---C03 C06---to---N/A C07---to---C07 C08---to---N/A C09---to---C08 C10---to---N/A I italicized the similar wire connections so I know what I have to change. Are you sure this is correct tho because I'm pretty sure all my lights work at the present time. The only thing not functioning that I know of is the fuel gauge, temperature gauge, the 3 green bulbs won't light up the ComboMeter when I turn on my headlights, and the cooling fan stays on after I pull the key out of the ignition. But I can turn it off by pulling the wiper stick down all the way and pushing it back up when the car's off. Are you sure the Australian version is the same as the Japanese version? Because if it is then I'll go by what you said. Thanks again. This post has been edited by JoKeRkId613: Sep 29, 2005 - 9:08 PM -------------------- ![]() |
Sep 29, 2005 - 11:06 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
All these wiring for the fuel gague. I would shoot myself.
Sep 30, 2005 - 7:27 AM
Nope, not sure if they are the same. I'm just working from the BGBs at Celicatech. There is only the diagram for australia and europe. If I had the cluster I'm sure I could get it to work without a problem. I do know that you've got something terribly wrong if your wipers turn off your car LMFAO.
Sep 30, 2005 - 1:37 PM
^gee, thanks. lol. just kidding. my dad was cracking up when i told him. then he almost died when he found out i was being serious. i'll go check the toyota dealer so those mo-fos can get me the japanese st205 because i also didnt see it. there's only one version of the at200 tho, right?
Sep 30, 2005 - 2:26 PM
QUOTE(JoKeRkId613 @ Sep 30, 2005 - 1:37 PM) ^gee, thanks. lol. just kidding. my dad was cracking up when i told him. then he almost died when he found out i was being serious. i'll go check the toyota dealer so those mo-fos can get me the japanese st205 because i also didnt see it. there's only one version of the at200 tho, right? [right][snapback]339907[/snapback][/right] LOL. I don't blame him. That's some funny sh!t. Only differences between AT200s would be OBDI and OBDII. You have OBDI since it was made before 1996 The wiring diagrams I'm using are for the OBDI so they should be exactly right. EDIT: I added the European ST205 chart under the Australian ST205 Chart here: http://www.6gc.net/forums/index.php?act=ST...t=0#entry339519 EDIT2: When/If you get the EWD for the Japanese ST205 would you mind sacanning them and making them available for us? This post has been edited by WannabeGT4: Oct 22, 2005 - 3:32 PM -------------------- ![]() Project ST204.5 99.88946% complete... |
Oct 7, 2005 - 6:13 PM
Wannabe, there is no way that we're on the same page... I tried everything you gave me and nothing worked at all. No needles, no lights. I wrote down some of the wires you connected to something else that didn't even exist...
Europe AT200---ST205 A01---to---A02 A02---to---A01 A03---to---?NO SRS LIGHT? A04---to---?NO SRS LIGHT? A05---to---?NO SEATBELT LIGHT? A06---to---B03 A07---to---B05 A08---to---A04 A09---to---B06 A10---to---A09 A11---to---N/A A12---to---N/A A13---to---?PARK, NEUTRAL, CLUTCH SWITCH? B01---to---B01 B02---to---N/A B03---to---B02 B04---to---A12 B05---to---N/A B06---to---B07 B07---to---B08 B08---to---B09 B09---to---B10 B10---to---B11 B11---to---B12 B12---to---N/A B13---to---B14 B14---to---C02 B15---to---B15 B16---to---B16 C01---to---N/A C02---to---C03 C03---to---N/A C04---to---C05 C05---to---N/A C06---to---C07 C07---to---C08 C08---to---?NO O/D OFF LIGHT? C09---to---?NO CRUISE CONTROL LIGHT? C10---to---C10 I have a 1994 A/T AT200. This is a 6th Gen ST205 European(It has rear fog light, no cruise light, no o/d off light...yes, it has srs and seatbelt lights tho so i dont know why the diagrams didnt) cluster I'm putting in. None of these colors even match up. I know maybe they're not supposed to but in the connections by purplegt4, at least most of the cluster worked and most of the wires matched up in color. Were all ST205's OBDII? Are you sure this is supposed to work? I doublechecked everything, not one color wire matched up but nothing worked. I did it exactly like you said. I bolded the wires that didn't exist on the plugs of the AT200 and the ST205. I dont see how you have them connected to something else. Thank, I appreciate what you're doing for me but please help me out and stick with me or else I'm stuck. Thanks in advance. What AT200 diagram are you using to be exact? -------------------- ![]() |
Oct 8, 2005 - 7:09 AM
If I use a multimeter, or one of those volt measuring things, how many volts or whatever should be passing through each wire? And how do you know if something is grounded correctly? Thanks.
| Lo-Fi Version | Time is now: September 1st, 2026 - 10:23 AM |
