> gauge cluster issues, need pics
post Sep 28, 2005 - 9:28 PM
cyb593
Joined Feb 22, '04
From USA
confused.gif confused.gif we got the cover off the needle but cant get the needle off of the speedometer. where is the dead point does anyone got a picture? and also do u have to push on that tab or pull up on it? we need to set the odometer to my current and i am trying to figure this out. i need pictures of how to do this. need as much help as possible as soon as possible. frown.gif
This post has been edited by cyb593: Sep 28, 2005 - 9:30 PM
post Sep 29, 2005 - 5:51 PM
cyb593
Joined Feb 22, '04
From USA
bump!!!
post Sep 29, 2005 - 7:55 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I wouldnt pop that needle off. resetting it is a pita.
I will return one day.
post Sep 29, 2005 - 10:41 PM
cyb593
Joined Feb 22, '04
From USA
well i need to set the odometer forward so i cant do it without removing the plates and the needles.
post Oct 6, 2005 - 11:13 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I ran into this problem too. At the end, I didn't want to remove the needles so I ended up without any gauge clusters.
post Oct 6, 2005 - 1:06 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Doggy, I beleive, gave directions on how to do it. The needle will flex enough to move it past the first stop then you'll have to pull the extension off of the trip odometer reset button then the needle will flex over that while the button is pushed down. Let the needle come to a stop and then mark the postion, take a picture, or make a mental note. When reinstalling the needle make sure that the guage cluster is in the same position as it was when the needle was removed. The orientation of the combonation meter is critical for proper calibration. You can check the accuracy of the speedometer with a GPS and reset the needle's postion according to your findings with the GPS. That is what I did and it works great.
Lo-Fi Version Time is now: September 1st, 2026 - 12:32 AM
