Sep 29, 2005 - 4:37 PM
Enthusiast ![]() Joined Jul 16, '03 From Boise, Idaho Currently Offline Reputation: 0 (0%) |
why is this doing this? and how do i fix it, ive played with the throttle cable at throttle body w/no luck. and also i know this has been asked before but my car puts out a puff of blue smoke when i start it after it sits for a couple hours. could this be oil setting inside the cyl. settling after a couple hours and if so could it be a piston ring leak
-------------------- My car = 0-60 in ~9sec
It's slow, I know |
Sep 29, 2005 - 5:34 PM
check your floor mats to make sure they are not making the gas pedal stick
the oil buring at start up is a common celica problem. its cause by leaky valves. really nothing major to worry about and many people never even get it fixed. just keep an eye out on your oil level -------------------- 15PSI - 30MPG - Megasquirt Tuned
Sep 30, 2005 - 1:41 AM
i figured it out twas my throttle cable too tight
It's slow, I know |
Sep 30, 2005 - 4:27 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
QUOTE(chicklover345 @ Sep 29, 2005 - 11:41 PM) i figured it out twas my throttle cable too tight [right][snapback]339768[/snapback][/right] i was about to recommend that but then id just be repeating you now wouldnt i? how did the cable get too tight to begin with? -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
| Lo-Fi Version | Time is now: May 25th, 2026 - 12:29 AM |
