> regriding the 7afe cam shaft
post Sep 29, 2005 - 9:17 PM
st_celica_killer
Joined Sep 23, '04
From fresno
i just wanted to know if its worth regriding the stock 7afe camshaft ??? since there no aftermarket camshaft...
post Sep 29, 2005 - 9:48 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
It's about $500 to do this isn't it? If you've already got a header, intake, exhaust, maybe ignition, and possibly ported and polished head, then yeah it might be worth it. There are a few things to do first though. I should have checked your profile to see what you have done before I typed this. But to anyone out there wanting to do this to a stock engine, better do some other things first. New cams won't even work right unless you have free flowing exhaust and intake. And unless it's really mild, you'll probably have to get bigger injectors and upgrade ignition.
EDIT: I looked at your profile. You might be ready for this in my opinion, especially if you've got the cash for it. I'd like to see an all-motor Celica build here. Maybe that's a bit ambitious.
This post has been edited by Bigmeanbulldog55: Sep 29, 2005 - 9:51 PM
Live Free, Be Happy
post Sep 29, 2005 - 10:00 PM
st_celica_killer
Joined Sep 23, '04
From fresno
well i'm building a 7afte with 4agze psiton...port and polishing the head with everything new from valve, regriding 7afe cam shaft.. etc.......... with a custom 7afe itb adaptor to fit the 20v itb with upgrade fuel injetor and going on the itb is a 20valve turbo intake manifold and here is the a pic of the same 20v turbo intake manifold that i bought
http://www.altarf.net/gallery/friendphoto/pic_1
This post has been edited by st_celica_killer: Sep 29, 2005 - 10:01 PM
post Sep 29, 2005 - 10:32 PM
FallenHero
Joined Dec 26, '02
From Alabama
are you smoking pot? To use a 7afe head on a built engine is like putting a restrictor plate on a nascar... it kills power. The 4ag head will give you better gains and it will be easier to get a ITB adapter. Plus, you can get any cams you want.
post Sep 29, 2005 - 10:38 PM
st_celica_killer
Joined Sep 23, '04
From fresno
well yes i'am on pot eheheheeh just gota love da ahah j/p tongue.gif anywaysss ...i know what your talking why not just go 7agte well i do but its that i have already have tons of part turbo part lying around the house from complete intercooler, blow off value, turbo timer, greddy emanage unit, from the pass turbo setup on another car sorrie but gota go 7afte for now
This post has been edited by st_celica_killer: Sep 29, 2005 - 10:42 PM
post Sep 30, 2005 - 12:47 AM
FallenHero
Joined Dec 26, '02
From Alabama
if you don't have a manifold, then the head swap won't be a problem.
post Sep 30, 2005 - 9:53 AM
nik
Joined Sep 30, '02
your going to have high compression with those 4agze pistons with the 7afe head
IMAO a stock 4ag heads flows as good or better than a stage 3 P&P job on a 7afe head
but if your set on keeping the 7afe and just turboing it
I have a few things you might want
ASP underdrive pulley
stock cams and gear
catch bottle (for pcv)
valve cover with new seal
intercooler piping 2.5"
let me know
This post has been edited by nik: Sep 30, 2005 - 10:19 AM
post Sep 30, 2005 - 10:48 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Don't think cams are bolt-on power... they require significant tuning... ignition, fuel, and especially timing. A MAJOR tuning drawback of the FE slave gear design is cam tuning...
post Sep 30, 2005 - 11:14 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Kwanza26 @ Sep 30, 2005 - 11:48 PM)
[right][snapback]340060[/snapback][/right]
Not that I'm doubting you, but why is it so bad? Is it because you can't move each seperately? I'm not real deap into the tuning world yet, I just haven't had much of option yet. It just seem like they're be too many times you'd nead to move them seperately. If you agust the timing on intake to advance it, it seems like exhaust would follow. I just want to know the reason it's so bad. If you don't reply, I'll see if I can't find the answer somewere on the net.
Live Free, Be Happy
post Sep 30, 2005 - 11:32 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Bigmeanbulldog55 @ Oct 1, 2005 - 4:14 AM)
[right][snapback]340073[/snapback][/right]
Depending on the cam profile... sometimes tuning for the best power, best torque, or whatever will make better results when one cam is retarded and the other advanced. This depends on the cam profile and other tuning... but it is a great limiting factor in cam tuning. Again I'll repeat... camshafts aren't bolt-on power. If you don't tune them... they can just make the engine run bad.
Lo-Fi Version Time is now: August 24th, 2026 - 12:32 PM
