> Wobbling @ low speeds, alignment issue?
post Oct 9, 2005 - 7:59 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
if a car wobbles a bit at low speeds is it just as simple as getting an alignment?
i had a car inspected and the mech says it wobbles a bit @ low speeds and he recommends that all it is is that it requires an alignment and 2 new front tires...
is this normally the case or could there be a more expensive problem i'd have to deal with?
This post has been edited by elvasoshexai: Oct 9, 2005 - 8:00 PM
06 Civic EX
My For Sale Thread
post Oct 9, 2005 - 9:07 PM
o0black0o
Joined Jul 14, '05
From Spring, Texas
What wobbles front or rear?
Front prolly does need a alignment, rear id suggest struts. or bad springs
post Oct 9, 2005 - 9:09 PM
elvasoshexai
Joined May 16, '05
i'm not sure.. i'm assuming the front wobbles since they are recommending 2 new front tires and alignment
06 Civic EX
My For Sale Thread
post Oct 10, 2005 - 1:16 AM
Junior
Joined May 5, '03
From Toronto
could be tires, alignment, balancing, bearings, a number of things.
post Oct 10, 2005 - 8:35 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
yeah it could be your bareings, ball joint. You wont notice the wheels being off balance until higherspeeds, and the alignment wont make wobble as much as just uneven ware, and pulls to one side.
post Oct 10, 2005 - 11:05 AM
elvasoshexai
Joined May 16, '05
i guess i'll ask why mech thinks it's tires/alignment instead of other things
06 Civic EX
My For Sale Thread
post Oct 11, 2005 - 8:37 PM
celicaGT96
Joined Aug 14, '05
From Corpus Christi Tx
what about for me guys????
my car doesnt really wobble or shake, but i feel it in the steering wheel and the pedal....it never used to do it before, and it just started recently.
any help please.....
post Oct 11, 2005 - 8:48 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE(celicaGT96 @ Oct 11, 2005 - 8:37 PM)
[right][snapback]343540[/snapback][/right]
High speeds slow speeds? brakeing driving cruising? If its higher speeds, it could be simple as the wheel balance. It its just driving all the time, it could be the wheel baring or the ball joint.
One thing, pop it on a jack, so the front wheels are i the air. See if they wobble in any direction.Like hold top and bottom. If it wobbles, then its the wheel barings or the ball joint. ( thats what im dealing with now, Il know by thursday if the ball joint fixs it.)
then grab the left and right side, if it wobbles then its the tierods.
If it dosnt wobble eioather way, its your wheel balance, your suspension warn or a messed up wheel or tire.
If it wobbles or shakes when braking it could be your pads or a warped rotor. That would only be braking though.
post Oct 16, 2005 - 1:03 PM
cyb593
Joined Feb 22, '04
From USA
gets your tires looked at the belt sin the tire can be seperating and cause that then u hit about 50 an dit goes away at high speeds. happen on my brothers camry.
post Oct 16, 2005 - 1:07 PM
shid
Joined Jan 8, '04
From LA
My car is in need of an alightment so badly.
If I let go of the wheel on the freeway, it will execute a beautiful 30 degree turn.
While driving at slow speeds across LA straights, the wheel moves back and forth like it was lubed for a hot date.
My roommate was like: #&@(#&(*@#
post Oct 17, 2005 - 9:40 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
set your car to neutral, jack up your car, put it on all four jack stands and by hand rotate all the wheels. IF any seems to wobble you got a dented rim, or a bad bearing. Could be tie rods too.
post Oct 20, 2005 - 7:35 PM
97GTinKC
From KC
I'd bet on bad tires, btdt
Lo-Fi Version Time is now: August 24th, 2026 - 9:44 PM
