Oct 10, 2005 - 5:23 AM
Enthusiast ![]() Joined Sep 2, '05 From England, Uk Currently Offline Reputation: 0 (0%) |
Well after going down to the local drag strip at the weekend all the big names were there with there products so i got my self a baileys dump valve any ways i got back home last night and just had to put it on once all fitted i started the car up it was fine took it for a run spot on this moarning i took the misses work whilst waiting in traffic and out of gear the car started to idle funny the revs were going up and down between 900rpm and 850rpm any ways after driveing back home i parked up and the car idled fine but then comeing work its doeing it again. Any idea's wot could be wrong do u think i have a vacume leek some were? or is it a comman problem when u fit a dump valve?
thanx Craig |
Oct 10, 2005 - 7:17 AM
sounds like you created a boost leak installing the valve.
Oct 10, 2005 - 8:50 AM
i think ive sorted the problem now it looks like with the dump valve being new it just needed freeing up cause i went home at dinner time and i kept driveing so the dump valve was kicking in and its seemed to off freed up now. Ill keep u all updated.
thanx craig |
| Lo-Fi Version | Time is now: September 14th, 2026 - 5:07 AM |
