Oct 11, 2005 - 10:22 AM
Enthusiast ![]() ![]() Joined Aug 29, '02 From Kelowna, BC Currently Offline Reputation: 0 (0%) |
Today is my first day off and I went right to work. I did a crude splice just to test my theories on EA1 pin 4 and pin 17 being spliced together. I plugged the fuse box back together and plugged the ECU connectors back into the ECU. I connected the battery and put the charger on boost and plugged that in also. I climbed in and crossed my fingers. I turned the key one click. The dash lit up like I remembered. I turned it to the next position. The engine light, oil light, etc. all came on like normal and after about 4 seconds they went out. I thought to myself, "hmmm, good sign so far". I turned the key one spot further to start. NO HESITATION AT ALL!!!!! (and I'm sure it was flooded).
It fired up on the first try! I can now be added to the COMPLETE list!!!!! just have to go back and redo that splice, put in the axles and connect the tail pipe. no exhaust yet, it dumps from the header. AND NO ERROR CODES COME UP!!! WOOOO-HOOOO!!!!! ![]() Things left to do: 1. (done)put axles back in place. 2. (done)put plastic back onto bottom of engine bay. 3. (done)look into tach problems, the 1994 tach does not work with the BEAMS motor. 4. (done) go to a muffler shop to tie the exhaust in. ____________________________________ It's on the road. Since my background is avionics, I am doing a system by system check to confirm no problems. ABS - working ok. Power steering - working ok ( still missing 2 vacuum lines on the pump and have no idea what they were for). Air Conditioning - working ok. - one line is VERY close to the header(1/2 inch) and will have to be tie-wrapped back out of the way. I am concerned that it might catch fire. Tach - I took my guages out and compared both sets of guages. The plastic circuit card on the back is wired very differently on the BEAMS guages. I noticed that the guages themselves are held in place with long screws and that also seems to be the electrical connection. Each screw has an abreviated name beside it. Both guages have the same abreviations. hhhhmmmmm. I wonder if........ I pulled tach from the BEAMS pack and swapped out with the one in my 94 guages. IT WORKS!!! I have no pictures of the guages yet as I did not have my camera when I did this. I will take the guages out later and take pictures. Cooling fans - with A/C running both fans turn on. I have yet to get the fans to turn on without the A/C. I believe this is due to the fact the the engine temps are very low and it might not be needed. It is a concern because when I pop the hood it smells very hot like something about to burn. The smell also might just be due to a header that I never had before, not sure. Maybe it's the A/C line getting very hot. must explore more. This post has been edited by Outsider: Sep 20, 2009 - 10:42 PM -------------------- ![]() 1994 GT-S (BEAMS) swap complete |
Outsider BEAMS Update...... IT LIVES!!!!!!! Oct 11, 2005 - 10:22 AM
nik great job now go drive that car Oct 11, 2005 - 10:32 AM
JoKeRkId613 Congrats Outsider. Hope everything else comes alon... Oct 11, 2005 - 10:32 AM
macavely congrats kid... can't wait to see that vid cli... Oct 11, 2005 - 10:42 AM
playr158 sweeeeeeeeeeeeeeeeeeet can't wait to hear it ... Oct 11, 2005 - 11:01 AM
95CelicaST Gosh! Lucky! Oct 11, 2005 - 11:41 AM
lagos thats great news! i cant wait for the vid! Oct 11, 2005 - 11:50 AM
FallenHero I can't wait to hear how she runs., Oct 11, 2005 - 12:34 PM
Coomer That's awesome! I can't wait to see so... Oct 11, 2005 - 3:32 PM
Consynx wowza
just keep editing this first post...pics, v... Oct 11, 2005 - 3:40 PM
soulshadow Make sure you burn some rubber, cream a few civics... Oct 11, 2005 - 4:23 PM
orvillescelica A full Beams swap complete! I thought i would ... Oct 11, 2005 - 4:52 PM
dstrbcelica w00t for you. i can't wait for the vids.
-ds... Oct 11, 2005 - 4:54 PM
Jdog1385 sickness Oct 11, 2005 - 5:31 PM
dustin15brown I can't wiat for the vids and details, the BEA... Oct 11, 2005 - 6:16 PM
BLINKYxMUNKEY awesome..can't wait for the videos. Oct 11, 2005 - 6:51 PM
defgeph congrats !!! all your hard work payed ... Oct 11, 2005 - 8:31 PM
zachattack15 awsome, cant wait to see some vids Oct 11, 2005 - 10:25 PM
ILuvMyCelica95 That's awesome outsider! congrats!- an... Oct 11, 2005 - 10:41 PM
BBoYRuGGeD freakin' awesome man!
bboy Oct 11, 2005 - 10:44 PM
Outsider video added to first post Oct 12, 2005 - 5:10 PM
defgeph freaking awesome man Oct 12, 2005 - 5:22 PM
dustin15brown QUOTE(defgeph @ Oct 12, 2005 - 10:22 PM)freak... Oct 12, 2005 - 5:31 PM
lagos great job...it started right up with no long crank... Oct 12, 2005 - 5:29 PM
celicaST great swap, sounds like you didnt have too much tr... Oct 12, 2005 - 5:57 PM
Junior Bravo...Mad respect. Oct 12, 2005 - 7:39 PM
SimmaDownNow Congratulations man. I hope to follow in your foot... Oct 12, 2005 - 10:02 PM
Silver94CelicaOwner Simply awesome. Once everything is finished and g... Oct 12, 2005 - 11:29 PM
Valo666 Finaly a canuck does somethin no one else does. Ho... Oct 13, 2005 - 1:36 PM
rascaca congratulation for the swap, it is a great engine... Oct 15, 2005 - 7:03 AM
kevstir Hi m8 what format do you have the wiring diagram o... Oct 16, 2005 - 6:03 PM
UKcelicaKev Sorry to dig up old threads guys, so take this an ... Oct 25, 2006 - 2:36 PM
playr158 can you hear your fuel pump?
lift up the rear seat... Oct 25, 2006 - 3:20 PM
UKcelicaKev Yeh done that mate, i ve pm'd outsider and he ... Oct 26, 2006 - 3:30 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 22nd, 2026 - 7:51 AM |
