Oct 11, 2005 - 4:32 PM
Enthusiast ![]() ![]() Joined Aug 14, '04 From Toledo, Ohio Currently Offline Reputation: 0 (0%) |
people are gonna hate me after all this...
i got my car out of the shop cuz they dont know what's going on. there's a lot of problems with the wiring and i want to get it narrowed down. let me explain the symptoms: first of all, the shop left the main white fuse plug unplugged, so needless to say, they couldnt get power to anything. within an hour of looking around, i figured that out and plugged it in. WHAMMO i got headlights (hi/low) the door chime, locks, lights on the doors, and the guage cluster lights up...thats about it. no sunroof, no power windows, cd player doesnt turn on, no blinkers, no windshield wipers, no fan for the vents. all minor stuff for now, i just want the car to start. now, when i turn the key to start up, i can hear the circuit opening relay click, but nothing else happens. i had a couple friends over to help out and we ran 12v straight to the starter and the fuel pump relay and got the motor cranking, but there was no spark so it wouldnt start. so with no power getting to a number of things, i want to go through all the leftover plugs that are layin around to see if they should be plugged into something. here's the first one. it's probably the EGT sensor. 1 black wire, 1 white wire. it comes out as shown in the 2nd pic. ![]() ![]() theres a lot more...i just want to go 1 at a time thanks a LOT in advance...ive come to find i dont know nearly enough to be doing this swap. shame on me. This post has been edited by gtfc115: Oct 12, 2005 - 11:15 AM |
gtfc115 GTFC's "What are these plugs" thread... Oct 11, 2005 - 4:32 PM
gtfc115 By the way, ChrisD from Alltrac.net did my harness... Oct 11, 2005 - 4:34 PM
lagos yeah im pretty sure that one is for you egt sensor... Oct 11, 2005 - 6:00 PM
gtfc115 k, thanks Lagos. before you guys think im just too... Oct 11, 2005 - 6:19 PM
gtfc115 anyone? Oct 12, 2005 - 2:31 PM
ChrisD Hey Cory,
OK, it sounds like your shop has done s... Oct 12, 2005 - 7:29 PM
gtfc115 yeah i lengthened that fat wire and connected it t... Oct 12, 2005 - 7:37 PM
gtfc115 here it is...it has a plastic cover on it (notice ... Oct 12, 2005 - 7:43 PM
gtfc115 i just spent like 2 hours ripping my dash apart to... Oct 12, 2005 - 7:53 PM
Rjb23 Check the big green fuse in the driverside kick pa... Oct 12, 2005 - 8:16 PM
gtfc115 checking....
hey Rjb im reading your thread on mr... Oct 12, 2005 - 8:20 PM
ChrisD The one with the plastic cover is a connector for ... Oct 12, 2005 - 8:22 PM
gtfc115 this and all the others look pretty corroded Oct 12, 2005 - 8:32 PM
gtfc115 +B wire is getting like .5 volts Oct 12, 2005 - 8:37 PM
ChrisD QUOTE(gtfc115 @ Oct 12, 2005 - 8:37 PM)+B wir... Oct 12, 2005 - 9:13 PM
Rjb23 Corrosion should be fine as long as that one is no... Oct 12, 2005 - 9:04 PM
gtfc115 yeah i've checked all the fuses, they all look... Oct 12, 2005 - 9:12 PM
gtfc115 let me go make sure im checking it right...i got a... Oct 12, 2005 - 9:16 PM
gtfc115 yup, definately only .5v... Oct 12, 2005 - 9:20 PM
lagos for all those little fuses, buy a little fuse test... Oct 12, 2005 - 9:23 PM
soulshadow If you starter won't start take a look at the ... Oct 12, 2005 - 9:25 PM
gtfc115 hmmmm, didnt know about the fuses on the passenger... Oct 12, 2005 - 9:33 PM
gtfc115 QUOTE(soulshadow @ Oct 13, 2005 - 2:25 AM)If ... Oct 12, 2005 - 9:34 PM
Rjb23 Did you plug the little black wire into the starte... Oct 12, 2005 - 9:58 PM
gtfc115 OMG OMG OMG OMG OMG i just opened the fuze box and... Oct 12, 2005 - 10:01 PM
gtfc115 the blinkers work now, the radio, the vents...i he... Oct 12, 2005 - 10:06 PM
gtfc115 the fuel pump relay is making a really loud buzzin... Oct 12, 2005 - 10:11 PM
Rjb23 Where is your fuel hose that goes from the fuel ra... Oct 12, 2005 - 10:20 PM
gtfc115 man this thing's a mess...
sorry, im a 3sgte ... Oct 12, 2005 - 10:28 PM
lagos damn dood. .that motor is CLEAN! i cant belie... Oct 12, 2005 - 11:47 PM
gtfc115 anyone think i should try starting it?
im just wo... Oct 13, 2005 - 10:29 AM
Rjb23 No get the fuel leak fixed first, and the missing ... Oct 13, 2005 - 4:01 PM
lagos you could start a major fire ...buy that cold star... Oct 13, 2005 - 4:16 PM
gtfc115 i fixed the leak...tried starting it, and i get no... Oct 13, 2005 - 5:11 PM
Rjb23 Do you for sure have no spark or are you just sayi... Oct 13, 2005 - 6:01 PM
gtfc115 took a plug out and it wasnt sparking.
also, i do... Oct 13, 2005 - 6:33 PM
lagos bust out the multimeter.... put the key to ON, and... Oct 13, 2005 - 7:31 PM
gtfc115 k here's what i got:
the larger black plug wi... Oct 13, 2005 - 7:49 PM
lagos sounds about right, just off the top of my head. ... Oct 13, 2005 - 8:03 PM
gtfc115 *sigh*
boy im starting to get angry that i spent ... Oct 13, 2005 - 8:14 PM
lagos QUOTE(gtfc115 @ Oct 13, 2005 - 8:14 PM)*sigh*... Oct 13, 2005 - 8:42 PM
gtfc115 no, it wasnt completely connected, so i snapped it... Oct 13, 2005 - 8:45 PM
lagos here is something i just realized about your car .... Oct 13, 2005 - 8:52 PM
gtfc115 a ground to the tranny from the battery? No i don... Oct 13, 2005 - 8:53 PM
lagos run a ground wire to it... it bet that **** will f... Oct 13, 2005 - 8:55 PM
gtfc115 can i just put it anywhere on the tranny? then ru... Oct 13, 2005 - 8:59 PM
celicast3sgte make it easier on urself the battery grounds to th... Oct 13, 2005 - 9:03 PM
gtfc115 well...now im worried that's not the problem..... Oct 13, 2005 - 9:07 PM
lagos there is like a 12mm bolt right on top of the tran... Oct 13, 2005 - 9:09 PM
gtfc115 ^^^^ Oct 13, 2005 - 9:11 PM
lagos hmm ... yeah thats the right spot for it.
do a g... Oct 13, 2005 - 9:13 PM
gtfc115 QUOTE(lagos @ Oct 14, 2005 - 2:13 AM)hmm ... ... Oct 13, 2005 - 9:21 PM
gtfc115 what about this ground? its just kinda hangin out... Oct 13, 2005 - 9:24 PM
Rjb23 That ground should run from the top of the alterna... Oct 13, 2005 - 9:31 PM
gtfc115 well...its bolted there, but nothing else is conne... Oct 13, 2005 - 9:46 PM
Rjb23 It should be bolted to the top of the alternator w... Oct 13, 2005 - 10:26 PM
gtfc115 QUOTE(Rjb23 @ Oct 14, 2005 - 3:26 AM)It shoul... Oct 13, 2005 - 11:17 PM
Rjb23 No they would match up. Oct 14, 2005 - 5:15 PM
gtfc115 i think once i get some money together, im gonna g... Oct 15, 2005 - 4:05 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 3:01 PM |
