> 3sge or 5sfte, cant decide
post Oct 13, 2005 - 11:33 PM
ummmx2
Joined Nov 6, '04
there are so many pros and cons to both the 3sge and 5sfte. although the 3sge is cheaper, im not sure i have the mechanical ability to swap the engine successfully although it would probably be more reliable than the turbo setup. however, the 5sfte makes more power, i can put it together, BUT it also costs more and is less reliable. the 3sge is also a tough motor to find. what do you guys think?
edit: i have a 5th gen, so if anything id prob. be swapping a 2nd gen 3sge
This post has been edited by ummmx2: Oct 13, 2005 - 11:34 PM
- ummmx2   3sge or 5sfte   Oct 13, 2005 - 11:33 PM
- - lagos   the major thing i would worry about the 3sGE engin...   Oct 13, 2005 - 11:36 PM
- - MonsterBOX   why not a gte its just as much as a ge   Oct 13, 2005 - 11:52 PM
- - Bigmeanbulldog55   QUOTE(lagos @ Oct 14, 2005 - 12:36 AM)the maj...   Oct 14, 2005 - 12:13 AM
- - lagos   you still need some wiring skills to hook up a sta...   Oct 14, 2005 - 12:35 AM
- - Bigmeanbulldog55   QUOTE(lagos @ Oct 14, 2005 - 1:35 AM)you stil...   Oct 14, 2005 - 1:32 AM
- - ummmx2   actually the 2nd gen 3sge is MUCH cheaper than all...   Oct 14, 2005 - 8:50 PM
- - Bigmeanbulldog55   What exactly is the 2nd gen 3sge? Did it come in ...   Oct 14, 2005 - 9:02 PM
- - lagos   QUOTE(ummmx2 @ Oct 14, 2005 - 8:50 PM)actuall...   Oct 14, 2005 - 9:44 PM
- - MonsterBOX   2nd gen 3sge is def not a beams so its prob not wo...   Oct 15, 2005 - 12:01 PM
|- - BLADDER_MASTER   QUOTE(MonsterBOX @ Oct 15, 2005 - 12:01 PM)2n...   Oct 15, 2005 - 1:46 PM
- - Bigmeanbulldog55   QUOTE(MonsterBOX @ Oct 15, 2005 - 1:01 PM)2nd...   Oct 15, 2005 - 12:09 PM
- - ummmx2   2nd gen 3sge came in the 5th gen celica overseas. ...   Oct 15, 2005 - 1:47 PM
- - Bigmeanbulldog55   So what if it only has 160hp? A stock B16 has som...   Oct 15, 2005 - 7:39 PM
- - soulshadow   Its true, but u should at least get a complete swa...   Oct 16, 2005 - 10:50 AM
- - MonsterBOX   ok well imho dont get a 3sge unless its a beams......   Oct 16, 2005 - 1:55 PM
- - kevstir   if your going 3s-ge m8 its ether the rev 3 172-177...   Oct 16, 2005 - 6:14 PM
- - Kwanza26   2nd gen 3SGE is great... but the 3rd gen can be ha...   Oct 17, 2005 - 12:19 AM
- - kevstir   having owned a Celica for the last 4 years with th...   Oct 17, 2005 - 3:46 AM
|- - BLADDER_MASTER   QUOTE(kevstir @ Oct 17, 2005 - 3:46 AM)having...   Oct 17, 2005 - 2:31 PM
- - ummmx2   but wouldnt the 2nd gen 3sge be a lot easier to wi...   Oct 17, 2005 - 12:35 PM
|- - BLADDER_MASTER   QUOTE(ummmx2 @ Oct 17, 2005 - 12:35 PM)but wo...   Oct 17, 2005 - 2:28 PM
- - Digndoug   QUOTE(Bigmeanbulldog55 @ Oct 14, 2005 - 9:02 ...   Oct 17, 2005 - 2:01 PM
- - kevstir   If i could i would m8 but theres no way im importi...   Oct 17, 2005 - 2:51 PM
Lo-Fi Version Time is now: August 4th, 2026 - 9:32 AM
