> Well, my turbo stopped spinning.. need some input, Intercooler = cause?
post Oct 14, 2005 - 6:04 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
Intro: Well, I took my car to celicagurl152003 and had quite a bit of expense put into it.
Throughout the work to my car, the intercooler "could not be installed" and I was told the car would be "fine, if not better" without it, due to the length of the piping. Ok, so I drive it home, seemed to run fine, minus something occasionally that seemed like a backfire if I punched it and tried to run the rev's up in the current gear.
Regardless, I was doing some electrical work this past weeked (7-10th), and I finished some of the electrical up, and got the battery charged, and went for a drive. THis is when I first noticed no boost. After it cooled and such, looked at it a bit, and asked some opinions of some of the alltrac people locally, didnt really get anywhere. Anyway, I had to change oil, and some other stuff under the hood, and finished that up, pulled it out my driveway, turned around, still no boost.
So, the real question: Anyway, my turbo currently will work about 10* back and forth from its current location, and then it feels like it hits an obstruction. It turns freely for the few degrees it does turn, but will turn no further.
What would cause this? Is it easily fixable? Would it be related to having no intercooler?
Heres a pic of the engine bay as it was until the turbo stopped functioning:
- mark_426   Well, my turbo stopped spinning.. need some input   Oct 14, 2005 - 6:04 PM
- - shin   you need a intercooler and new turbo!!   Oct 14, 2005 - 6:08 PM
- - lagos   how long did u drive without and intercooler and d...   Oct 14, 2005 - 6:11 PM
- - mark_426   I have the intercooler - it is currently installed...   Oct 14, 2005 - 6:13 PM
- - lagos   well.. .that probably killed it. compressor surge ...   Oct 14, 2005 - 6:19 PM
- - Rjb23   Uhmm yea turbo + no intercooler = dun dun duhh...   Oct 14, 2005 - 6:19 PM
- - mark_426   I had them rebuild the motor while they were paint...   Oct 14, 2005 - 6:23 PM
- - jgreening   I don't think running without an intercooler w...   Oct 14, 2005 - 6:50 PM
- - Rjb23   Stock st185 do not have blow off valves.   Oct 14, 2005 - 7:38 PM
|- - jgreening   QUOTE(Rjb23 @ Oct 14, 2005 - 7:38 PM)Stock st...   Oct 14, 2005 - 7:54 PM
- - mark_426   I did/do have a BOV though... and it was first set...   Oct 14, 2005 - 7:39 PM
|- - jgreening   QUOTE(mark_426 @ Oct 14, 2005 - 7:39 PM)I did...   Oct 14, 2005 - 7:56 PM
- - GT4WRC   It is quite feasible to run a turbo without an int...   Oct 14, 2005 - 8:14 PM
- - lagos   QUOTE(GT4WRC @ Oct 14, 2005 - 8:14 PM) Take y...   Oct 14, 2005 - 8:31 PM
|- - GT4WRC   QUOTE(lagos @ Oct 14, 2005 - 8:31 PM)QUOTE(GT...   Oct 14, 2005 - 9:14 PM
- - mark_426   I have it off, and I cannot turn it with my finger...   Oct 14, 2005 - 8:39 PM
- - jgreening   Thanks for pointing it out...I have never seen tha...   Oct 14, 2005 - 8:43 PM
- - mark_426   The BOV has been hooked up all along. However, the...   Oct 14, 2005 - 9:03 PM
- - jgreening   Gary, many of us running swaps are using the Gen I...   Oct 14, 2005 - 9:24 PM
- - mark_426   Guys, can I run the car with the turbo not spinnin...   Oct 14, 2005 - 9:25 PM
- - lagos   QUOTE(GT4WRC @ Oct 14, 2005 - 9:14 PM)QUOTE(l...   Oct 14, 2005 - 9:27 PM
- - lagos   QUOTE(mark_426 @ Oct 14, 2005 - 9:25 PM)Guys,...   Oct 14, 2005 - 9:35 PM
- - mark_426   Where should I try to get a replacement CT26.. or ...   Oct 14, 2005 - 9:37 PM
- - lagos   look on ebay for a used one   Oct 14, 2005 - 9:39 PM
- - jgreening   or the parts for sale section of mr2oc.com. You c...   Oct 14, 2005 - 9:40 PM
- - mark_426   Shin suggested ATS - Is it worth the extra money ...   Oct 14, 2005 - 9:43 PM
- - jgreening   The nice thing about the ct27 is that it is an upg...   Oct 14, 2005 - 9:49 PM
- - playr158   QUOTEI was told the car would be "fine, if no...   Oct 14, 2005 - 11:17 PM
- - GT4WRC   So even if the AFM was still plugged in and only t...   Oct 15, 2005 - 1:48 AM
- - lagos   QUOTE(GT4WRC @ Oct 15, 2005 - 1:48 AM)So even...   Oct 15, 2005 - 1:57 AM
- - GT4WRC   Glad I have a MAP sensor then As previously sa...   Oct 15, 2005 - 3:22 AM
- - Driveby   You need to find out exactly why the old turbo die...   Oct 15, 2005 - 6:33 AM
- - presure2   yea, sounds like you snaped the shaft. not good. c...   Oct 15, 2005 - 6:38 AM
- - mark_426   QUOTE(mark_426 @ Oct 14, 2005 - 7:04 PM)Anywa...   Oct 15, 2005 - 9:41 AM
- - Consynx   if either side will only more 10* definately do no...   Oct 15, 2005 - 11:55 AM
- - zipstrips   i put $$ on the shaft snapped from lack ...   Oct 15, 2005 - 4:02 PM
- - mark_426   THe BOV has never been removed from the car. When ...   Oct 15, 2005 - 4:10 PM
- - zipstrips   mark, u cannot bybass the turbo and drive it aroun...   Oct 16, 2005 - 1:08 PM
- - Rjb23   Hey mark are you talking to Billy? I just dropped ...   Oct 17, 2005 - 7:00 PM
- - mark_426   Small world, same guy, Billy Roberts. I already ...   Oct 17, 2005 - 7:58 PM
- - Rjb23   Probably did, I live 2 mins from his shop.   Oct 17, 2005 - 8:24 PM
Lo-Fi Version Time is now: August 26th, 2026 - 11:47 AM
