> ABS Light, Found It .....
post Oct 16, 2005 - 11:28 AM
macavely
Joined Nov 4, '02
Well last night after picking up the g.f from work .. pulling into her drive way the ABS light pops up .. Damn i fix one thing on this car and another thing goes wrong.... i'm considering selling this thing again .... not at much as before... but i don't know if i'll be able to deal with anymore problems....
This post has been edited by macavely: Oct 19, 2005 - 4:06 AM
post Oct 16, 2005 - 11:29 AM
ILuvMyCelica95
Joined Dec 16, '02
ps. Are you going on Sat? hmm?
post Oct 16, 2005 - 11:54 AM
mac, ignition in the ON position,
bridge E1 & TC in the diagnostics box, just like checking codes, read the code from the ABS light, and call me wink.gif
codes 31-34 are the sensors @ each wheel.
FR(31) FL(32)
RR (33)RL (34)
post Oct 16, 2005 - 12:55 PM
Mr_E
Joined Nov 16, '04
From UK
What he said.
I've got a post with a link to all the ABS codes somewhere.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Oct 16, 2005 - 8:58 PM
macavely
Joined Nov 4, '02
thanks manny i'll check it out in a few...
post Oct 17, 2005 - 6:15 PM
macavely
Joined Nov 4, '02
ok doesn anyone know what it means when the ABS light turns off then on ..
ran the test and just got the light flashing once ..
post Oct 17, 2005 - 9:21 PM
when you got your new axel...did you make sure it was an abs one?
post Oct 18, 2005 - 12:41 AM
macavely
Joined Nov 4, '02
QUOTE(lagos @ Oct 17, 2005 - 9:21 PM)
[right][snapback]345770[/snapback][/right]
yea.. none ABS axels won't fix.. thats why i have a set in my trunk....
post Oct 19, 2005 - 4:04 AM
macavely
Joined Nov 4, '02
finally got the code.. had to look in the BGB .... i needed to remove the short pin ...
well i got 2 codes.... 31 and 36
and for anyone one that wants to know here are a list of codes
Code 11
Open in solenoid relay circuit. Check actuator wiring
harness, solenoid relay, solenoid relay wiring harness and solenoid
relay connector. See SOLENOID RELAY under COMPONENT TESTING.
Code 12
Short in solenoid relay circuit. Check actuator wiring
Code 13
Open in pump motor relay circuit. Check actuator wiring
harness, pump motor relay, pump motor relay wiring harness and pump
motor relay connector. See MOTOR RELAY under COMPONENT TESTING.
Code 14
Short in pump motor relay circuit. Check actuator wiring
Code 21
Open or short circuit in solenoid for right front wheel.
Check actuator solenoid, wiring harness and connector. See ACTUATOR
CHECK under DIAGNOSIS & TESTING. See ABS ACTUATOR under COMPONENT
TESTING.
Code 22
Open or short circuit in solenoid for left front wheel. Check
actuator solenoid, wiring harness and connector. See ACTUATOR CHECK
under DIAGNOSIS & TESTING. See ABS ACTUATOR under COMPONENT TESTING.
Code 23
Open or short circuit in solenoid for right rear wheel. Check
Code 24
Open or short circuit in solenoid for left rear wheel. Check
Code 31
Malfunction of right front wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness and connector. See SPEED
SENSOR DIAGNOSTICS under DIAGNOSIS & TESTING. See FRONT SPEED SENSORS
Code 32
Malfunction of left front wheel speed sensor signal. Check
Code 33
Malfunction of right rear wheel speed sensor signal. Check
SENSOR DIAGNOSTICS under DIAGNOSIS & TESTING. See REAR SPEED SENSORS
Code 34
Malfunction of left rear wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness, and connector. See SPEED
Code 35
Open in left front or right rear wheel speed sensor circuit.
Check speed sensor, sensor rotor, wiring harness and connector. See
SPEED SENSOR DIAGNOSTICS under DIAGNOSIS & TESTING. See appropriate
speed sensor testing under COMPONENT TESTING.
Code 36
Open in right front or left rear wheel speed sensor circuit.
Code 37
Rear speed sensor rotor malfunction. Check rear sensor
rotors.
Code 41
Battery voltage is less than 9.5 volts or more than 16.2
volts. Check battery and voltage regulator.
Code 51
Actuator pump motor is locked or pump motor circuit open.
Check pump motor, pump motor relay, vehicle battery, actuator wiring
harness, connectors, actuator pump motor circuit and actuator ground
bolt. See ACTUATOR CHECK under DIAGNOSIS & TESTING. See MOTOR RELAY
ABS Light Always On
Malfunction of ABS ECU. Inspect ABS ECU connector for proper
installation and undamaged terminals. Repair as necessary. If
connector is okay, temporarily substitute known good ABS ECU. Retest
system.
post Oct 19, 2005 - 3:36 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
front wheel speed sensor is out. no biggie man not worth selling the car over it.
post Oct 19, 2005 - 4:28 PM
J-TYPE
Joined Mar 16, '05
From Toronto, Ontario
what's the price range for replacing a wheel speed sensor?
post Oct 19, 2005 - 6:02 PM
macavely
Joined Nov 4, '02
QUOTE(J-TYPE @ Oct 19, 2005 - 4:28 PM)
[right][snapback]346519[/snapback][/right]
i think toyota sells it for 220 $
post Oct 19, 2005 - 6:13 PM
I'm sure you can find a used one cheaper though.
post Oct 19, 2005 - 11:20 PM
I just "fixed" my ABS light last night. I pulled the bulb biggrin.gif Damn right speed sensor mad.gif
post Oct 19, 2005 - 11:34 PM
macavely
Joined Nov 4, '02
from the codes i got i'm hoping if i find the open it will fix the problem.... and nothing is wrong with the sensor itself ..
Lo-Fi Version Time is now: June 10th, 2026 - 10:05 AM
