> Handling Issues
post Oct 19, 2005 - 12:14 AM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
Over the last few days, there has been a certain 'vagueness' about the handling on my car. Seemed to start after I fitted the Cusco lower brace. Initially put it down to the alignment needing re-doing, but gradually got worse, making me think something else was causing the problem.
Finally had the time to get the car up on a hoist this morning for a good look and a 'spanner check'. Upon closer inspection, the passenger side superstrut figure of 8 arm caught my attention. The split pin and locking cap had come off and the nut was nice and loose. No wonder the car felt awful to drive! Odd thing is that the figure of 8 arm was replaced nearly a year ago and hadn't been touched since. The fact that a split pin could simply 'vanish' has me completely stumped confused.gif At least it was an easy fix and the car is no much nicer to drive. But the fact that a split pin can simply disappear like that is a bit worrying!
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Oct 19, 2005 - 12:26 AM
ILuvMyCelica95
Joined Dec 16, '02
sounds odd.
post Oct 20, 2005 - 12:55 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Thats nothing, a bolt holding up the caliber bracket in my car went missing and I still don't know what happend to it! The other one was about to fall right off and it was so loose, that everytime I braked it sound like a pig squeal! I barely got home.
post Oct 20, 2005 - 3:50 AM
GT4WRC
Joined Mar 17, '05
If the nut had come off completely, then there was a 99% chance of the lower arm becoming disconnected from the suspension strut. If that had happened, it would have been extremely messy - and expensive. Assuming that it didn't happen at speed and I lived to tell the tale of course wink.gif
Gary
GT-Four spec list
Lo-Fi Version Time is now: June 12th, 2026 - 9:01 AM
