Oct 22, 2005 - 2:26 PM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From Corpus Christi Tx Currently Offline Reputation: 5 (100%) |
I just want the best for my celica even if it cost alot it would be worth it to me.
Why is this oil sopposed to be soo good, and would any of yall recommend it? |
Oct 22, 2005 - 7:07 PM
Enthusiast ![]() Joined Sep 9, '05 From Modesto, CA Currently Offline Reputation: 0 (0%) |
I've used it for almost a year now and had no problems with it. Kinda has a good racing smell rather then regular oil when your driving hard. I've used it in both my 2000 and 1990 GT-S's. They let me have a free dyno after I put some in and got about 2whp difference.
Oct 22, 2005 - 7:44 PM
lol are you serious? How would the oil affect horse power though?
Oct 23, 2005 - 12:14 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
royal purple is awesome stuff.
Nuff said -------------------- ![]() I will return one day. |
Oct 23, 2005 - 12:36 AM
QUOTE(Celicaguy13 @ Oct 22, 2005 - 7:07 PM) I've used it for almost a year now and had no problems with it. Kinda has a good racing smell rather then regular oil when your driving hard. I've used it in both my 2000 and 1990 GT-S's. They let me have a free dyno after I put some in and got about 2whp difference. [right][snapback]347853[/snapback][/right] Like i said earlier........ 2whp sounds great to me although kinda hard to believe |
Oct 23, 2005 - 5:00 AM
Enthusiast ![]() Joined Jul 5, '05 From New York ~ San Francisco Currently Offline Reputation: 0 (0%) |
Royal Purple is a great motor oil to use, I use Mobil 1 & Royal Purple on diffrent cars. Royal Purple is on the high price side & I can't truly tell the diffrence between Mobil 1 & RP
This post has been edited by Project95St202: Oct 23, 2005 - 5:01 AM |
Oct 23, 2005 - 7:35 AM
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
i ONLY use royal purple!!!`
Oct 23, 2005 - 1:43 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Amsoil owns royal purple! I used to run royal purple in my bike, it was good but I switched to amsoil and it was so much smoother. Amsoil is the top of the line oil as far as I'm concerned.
Oct 23, 2005 - 3:54 PM
oil can indeed give you a 2whp gain i've seen over 10whp gained by RP in a wrx by using ONLY rp fluids crank, tranfer ect.. over the stock
the reason being is oil does wat? LUBRICATE and cut down on frictional loss and heat by reducing friction via better oil you reduce heat and drag on parts which "frees" up a itty bitty hp |
Oct 23, 2005 - 10:43 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) |
royal purple is defintely the best
Oct 23, 2005 - 10:45 PM
Why is this the first time im hearing about this stuff?
Oct 24, 2005 - 6:08 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 30, '03 From IL Currently Offline Reputation: 15 (100%) |
same here
never heard of it before -------------------- PROJECT 6TH GEN
![]() <FS: Things up for grabs> <Progress> |
Oct 25, 2005 - 11:53 PM
I never heard of it either until I went to dyno last year with my GT-S. They asked me if I wanted to try the oil and I said sure. I went back a week later to get it redyno'd and I gained 2whp. The thing is that when I went back to redyno, it was about 10 degrees hotter and a little more humid. I don't know how much it affects a dyno but I still gained.
Oct 25, 2005 - 11:57 PM
By the way, the benefits of using Royal Purple isn't just the lil hp you gain... But it also helps your engine last longer too. So paying a little more for oil is a good idea. The only thing I don't understand is how it's suppose to improve mileage like it says on the bottle. I've never actually checked to see if it did or not before I started using it.
Oct 26, 2005 - 12:28 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
never heard of it before, but after reading these comments i think ill give it a shot next oil change. ill post if i see a change in mpg. it makes sense, but i expect it to be very minimal if at all noticeable taking into account statistical variance.
-------------------- ![]() I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Oct 26, 2005 - 6:08 AM
my sr gets 24-29 mpg
Oct 26, 2005 - 9:45 PM
maybe i'll try it again, but like others... i'd never heard of it before
Oct 27, 2005 - 9:00 AM
Enthusiast ![]() Joined Jun 14, '05 From colorado Currently Offline Reputation: 0 (0%) |
i ordered some last week and it should be here today, gonna try it for the first time
Oct 27, 2005 - 6:08 PM
QUOTE(toyotatech @ Oct 27, 2005 - 9:00 AM) i ordered some last week and it should be here today, gonna try it for the first time [right][snapback]349576[/snapback][/right] let us know how it goes, and if you feel its worth it. |
Oct 27, 2005 - 6:28 PM
I think some of you are getting the wrong idea of what the oil is mainly made for. I think it's designed more to increase the life of the engine rather then increasing the performance. I highly doubt you'll be able to feel the actual difference but it's there.
| Lo-Fi Version | Time is now: June 23rd, 2026 - 9:50 PM |
