Oct 25, 2005 - 12:32 PM
Enthusiast ![]() Joined Jul 5, '05 From New York ~ San Francisco Currently Offline Reputation: 0 (0%) |
Ok yesterday night I got really bored so I decided to play with the audio system, Which I started of from the battery (Used 4 gauge wire) to circuit breaker & so on. Installed 2 amps, 2 component speakers & 1 sub
Amp #1 JL 450/4 for 2 set front & back component systems Amp #2 JL 500/1 for single 10W6 Which I got to install everything, turn it on .......... Sounds pretty good ......... Hmmm what is this noise I wanted to make sure everything was still in working condition so I drove around the block ......... Every time I accelerated the car from the speakers or from some where it started to make weeeeeeing weeeeeeing weeeeeeing noise. As I accelerated more the noise got louder. Well I need a help with this because I never seen this happen with my other cars, Is it the ground? Is the battery not strong enough? alternator? Or is it because it's an old car? Help me fix this problem this weeeeeeing noise is driving me nutz. |
Oct 25, 2005 - 12:35 PM
It's most likely the ground for the amps...where did you ground them? Make sure you ground them to a solid piece of the chassis. If there's paint, scrape it off so you get good contact.
Oct 25, 2005 - 12:38 PM
QUOTE(Coomer @ Oct 25, 2005 - 12:35 PM) It's most likely the ground for the amps...where did you ground them? Make sure you ground them to a solid piece of the chassis. If there's paint, scrape it off so you get good contact. [right][snapback]348842[/snapback][/right] See that's what I thought but some reason I wanted to make sure ..... Thanks alot coomer .... I kinda thought that paint would mess things up as well but once again thanks alot coomer for the help & if you need to make space for forum you more then welcome to delet this post |
Oct 25, 2005 - 8:44 PM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '04 From VA, USA Currently Offline Reputation: 0 (0%) |
or if you ran the RCAs and power together, that could potentially be a prob
Oct 27, 2005 - 11:12 AM
QUOTE(Pali_playa @ Oct 25, 2005 - 9:44 PM) or if you ran the RCAs and power together, that could potentially be a prob [right][snapback]349009[/snapback][/right] thats prolly whats causing it. you should always run your power wires as far away from the signal wires as possible, to avoid the kinda of interferance your discribing. -------------------- Former Team 5SFTE pro member ;)
Oct 27, 2005 - 12:22 PM
Ok grounding was done .... Still hearing the sound .... RCA & power cable no where near each other. Well my cars in the shop at this moment getting some jobs done. so can't really work on it but any other suggestions ?
It's not the ground or RCA next to power cable. |
Oct 27, 2005 - 1:17 PM
are both amps on the same ground? cause they should be
Oct 27, 2005 - 1:19 PM
QUOTE(Pali_playa @ Oct 27, 2005 - 1:17 PM) are both amps on the same ground? cause they should be [right][snapback]349647[/snapback][/right] Yes they're both on the same ground ..... Ahhh this is driving me nutz |
Oct 27, 2005 - 1:22 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) |
-Wrap e-tape around the RCA connections on the back of the deck
-Run RCAs down passenger side, power/remote down driver's side -Buy a ground loop isolater...or diy ground loop isolater. Get a few short pieces of black wire. Then strip off each end connect one end to the ground terminal of the amp along with your actual ground and the other end put in your RCA jack...do it for all of the RCA jacks on the amp. Looks kind of ghetto but it works. i dont really want to go take pictures of it but if you need pictures i will post them, just post on here that you need em. one more thing. why do you have components in the back? That's very pointless and will huyrt your ears at high volumes. if I were you I would bridge that amp down to two channels and just amp the fronts...and then fade your deck all the way to the front. creating a front sound stage definitely increases clarity and quality of the sound you hear. plus sending more power to those fronts will let you turn down the gains on the amp decreasing distortion. This post has been edited by snadman: Oct 27, 2005 - 1:25 PM -------------------- 95 Toyota Celica GT
Oct 27, 2005 - 2:45 PM
QUOTE(snadman @ Oct 27, 2005 - 1:22 PM) -Wrap e-tape around the RCA connections on the back of the deck -Run RCAs down passenger side, power/remote down driver's side -Buy a ground loop isolater...or diy ground loop isolater. Get a few short pieces of black wire. Then strip off each end connect one end to the ground terminal of the amp along with your actual ground and the other end put in your RCA jack...do it for all of the RCA jacks on the amp. Looks kind of ghetto but it works. i dont really want to go take pictures of it but if you need pictures i will post them, just post on here that you need em. one more thing. why do you have components in the back? That's very pointless and will huyrt your ears at high volumes. if I were you I would bridge that amp down to two channels and just amp the fronts...and then fade your deck all the way to the front. creating a front sound stage definitely increases clarity and quality of the sound you hear. plus sending more power to those fronts will let you turn down the gains on the amp decreasing distortion. [right][snapback]349649[/snapback][/right] No need for pictures I kind of know what they are & I guess I could hide them some where This post has been edited by Project95St202: Oct 27, 2005 - 2:46 PM |
| Lo-Fi Version | Time is now: June 10th, 2026 - 11:17 PM |
