Oct 30, 2005 - 3:36 PM
Enthusiast ![]() Joined Oct 3, '04 From NC Currently Offline Reputation: 0 (0%) |
5 months ago when i lowered the celica i used the tanabe springs which have turned out to be great, i put new kybs in the back but left the original struts in the front. today the rear struts are already knockin, while the oem are still holdin strong with a 2.2 drop. Has anyone though or noticed that the toyota struts are more durable then kybs? or is it just luck.
Oct 31, 2005 - 12:29 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
If you used the kyb gr2's, then you used 'toyota' struts. The gr2's are OEM; the knocking is more likely coming from your strut mounts or sway bar bushings. I would check those out before dropping any money on new struts.
Oct 31, 2005 - 6:50 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
I thought the Toyota struts are KYBs?
Oct 31, 2005 - 9:18 PM
Enthusiast ![]() ![]() Joined May 19, '03 From NJ Currently Offline Reputation: 0 (0%) |
I bet on the strut mounts too.
Oct 31, 2005 - 10:53 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) |
go for the toyota struts if you can afford them. check mounts
This post has been edited by Jdog1385: Oct 31, 2005 - 10:54 PM |
Nov 8, 2005 - 12:56 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
my own are AGX's with custom short struts.
This post has been edited by Punch: Nov 8, 2005 - 12:57 AM |
Nov 8, 2005 - 1:17 AM
GR2's are OEM replacements. OEM toyota shocks are made by Tokico. There aren't any direct replacement AGX shocks... but 2nd gen MR2 Shocks are similar enough that they can be fitted (opposed of course... MR2 rears for Celica fronts, MR2 fronts for Celica rears)... but this requires custom fabrication to the strut casings...
-------------------- "It's ok to be naked girl... I'm an artist!"
Nov 8, 2005 - 1:56 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
Had my stock Toyota Struts on my old celi for 3 years on Intrax springs, changed springs to Tein, left the stock struts. They are still holding strong and no problems with them AT ALL..
-------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Nov 8, 2005 - 9:37 AM
QUOTE(Kwanza26 @ Nov 8, 2005 - 6:17 AM) GR2's are OEM replacements. OEM toyota shocks are made by Tokico. There aren't any direct replacement AGX shocks... but 2nd gen MR2 Shocks are similar enough that they can be fitted (opposed of course... MR2 rears for Celica fronts, MR2 fronts for Celica rears)... but this requires custom fabrication to the strut casings... [right][snapback]354482[/snapback][/right] my custom set up is similar to what you are saying... there is hardley any thing for the celi most of my perfomance & susension are custom... This post has been edited by Punch: Nov 8, 2005 - 9:40 AM |
Nov 8, 2005 - 12:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
after reading this thread, i think i might just install my sportlines now. was going to wait to buy new struts.
-------------------- ![]() I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Nov 8, 2005 - 3:55 PM
newer struts will be stiffer cuz they newer. they last between 80-100k miles. depending how bad the conditions of the road are.
Nov 16, 2005 - 1:15 PM
so the original struts are better, kyb are replacements but not the same quality as toyota originals. as far as the noice the rear struts make when i go over a bump or a ditch which is like a CLUMK i dont know if it is the struts themselves. what should i look for when i look at the mounts to see if they're ok, and also i just remember i did forget to put the bump stops back in when i put the kybs in would that be a problem?
Nov 16, 2005 - 1:49 PM
All replacement parts meet OEM standards or better.
Nov 26, 2005 - 1:22 PM
looking for some old front struts...
Jul 16, 2006 - 5:46 PM
Sorry to bring back an old post but is it true since toyota struts are made by tokico so does this mean KYB's are not even all that compared to Genuine Toyota Struts? Should I just get OEM struts.
Jul 16, 2006 - 5:59 PM
kyb are direct oem replacements , i dont think they make mcphersons anymore...if you want a performance strut, try bilstein
Jul 16, 2006 - 7:34 PM
edit
This post has been edited by jgreening: Jul 16, 2006 - 7:43 PM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Jul 17, 2006 - 7:41 AM
where and how do i buy bump stops? where does it install?
Jul 17, 2006 - 9:55 AM
i think the bump stops are those foam like pieces that go on the shock covered by the dust boot.
Jul 17, 2006 - 4:40 PM
Is that something that can be bought from a regular parts store or something that needs to be bought from an OEM dealer?
| Lo-Fi Version | Time is now: August 4th, 2026 - 9:12 AM |
