Oct 31, 2005 - 9:36 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 25, '03 From cranston RI Currently Offline Reputation: 0 (0%) |
the search wont let me do LSD, and if i search even just "slip" the four topics it brings up are "where can i get a LSD for the celica"...
so heres my question... what IS a lsd, and what does it do? sorry i dont know too much about engines... -------------------- ![]() |
Oct 31, 2005 - 9:47 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jul 5, '05 From Arlington, TX Currently Offline Reputation: 2 (100%) |
Oct 31, 2005 - 9:48 PM
A differential is a part that allows two wheels opposite one another to turn at different speeds. This is necessary for a number of reasons but the most important is that during turning, the outside wheel will turn faster since it has more ground to cover. If there was no differential (or a locked differential) the wheels would turn at exactly the same speed and one tire would bounce during cornering. As a result, many cars come with "open" differentials so that the wheels are completely independent. The problem with an open differential is that it is not the best for traction. If one wheel is on loose pavement and begins to spin, the other wheel will get most of the power and the power distribution will be very unbalanced. To combat this, the limited slip differential was created (there are more than 15 different types of LSD's). This gives the benefit of an open differential for turning while providing better traction for performance reasons. HTH.
| Lo-Fi Version | Time is now: August 26th, 2026 - 8:40 PM |
