Nov 1, 2005 - 11:16 AM
i find most people probably don't read this but eh oh well
its really good stuff breaks it down by group of tire the each catagory wet, dry, handling, hydroplane resistance http://www.tirerack.com/tires/surveyresults/index.jsp |
Nov 1, 2005 - 11:28 AM
Enthusiast ![]() Joined Oct 21, '05 From Los Angeles, CA Currently Offline Reputation: 0 (0%) |
that's a good link
-------------------- '94 Tercel
USDM 5EFE * OEM MR-S Rims * Kumho ECSTA ASX 205/50R15 * NST Short Shifter estabon anti-lift plates * KYB GR2 Shocks & Struts * Eibach Pro Kit * Whiteline Rear Sway Bar Paseo Sway Bar * Paseo Front Brakes * Momo Shift Knob * Paseo Front Seats JDM OEM Toyota Altezza Side Markers * Corsa Tailights * Corsa Grille * Corsa Trunk Garnish http://www.socaltercel.com |
Nov 1, 2005 - 5:38 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 16, '04 From UK Currently Offline Reputation: 0 (0%) |
Heh. Guess what rubber I run.
-------------------- JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000 Needing another one 18000 miles later, bloody annoying. |
Nov 1, 2005 - 5:45 PM
good find, it will help me out a lot cause my tires are pretty much shot right now.
those Avon Tech M550 A/S look like a good bang for the buck This post has been edited by lagos: Nov 1, 2005 - 5:49 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Nov 2, 2005 - 9:14 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
This post has been edited by 97lestyousay: Apr 5, 2012 - 6:50 AM -------------------- JDM guy made me do it.
Nov 2, 2005 - 9:41 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
My nitto tires are pretty impressive. They are steel inforced inside and its save me a lot of times on dirt roads and the road itself. I remember one time when some idiot dropped a box of nails on the road. I happened to just run right over them and when I was home and coming back again on the road again. There was like two nails stuck on my tires. They actually didn't penetrate all the way inside the tires so I was so lucky. Perhaps due to the steel reinforcement.
Nov 2, 2005 - 6:00 PM
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
I wouldn't trust that rating very much. It'd be nice if they compared all major brands instead of the ones that they make the most profit off of.
Nov 3, 2005 - 4:47 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Car and Driver just came out with a test on the top 11 performance tires.. the results are as follows..
1. Goodyear Eagle F1 GS-D3 2. Continental ContiSportContact 2 3. Yokohama Advan Neova AD07 4. Michelin Pilot Sport PS2 5. Hankook Ventus R-S2 Z212 6. Dunlop SP Sport Maxx 7. Pirelli P Zero Rosso Asimmetrico 8. Toyo Proxes T1R 9. Bridgestone Potenza RE050A 10. BF Goodrich g-Force T/A KD 11. Kumho Ecsta MX This was done through Tire Rack using 225/45R-17's -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Nov 3, 2005 - 5:23 PM
QUOTE(lagos @ Nov 1, 2005 - 5:45 PM) good find, it will help me out a lot cause my tires are pretty much shot right now. those Avon Tech M550 A/S look like a good bang for the buck [right][snapback]351570[/snapback][/right] Thats what I run and I have been pleased. They are a little softer than the Continental Conti-extreme contacts I used to run. They do have a touch more road noise though. I will probably by Pirelli P Zero Nero M & S next time. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Nov 3, 2005 - 5:46 PM
i guess ill go for the pirelli then .. good to know
hope they last longer then my kumho 711s -------------------- 15PSI - 30MPG - Megasquirt Tuned
Nov 4, 2005 - 5:10 PM
QUOTE(lagos @ Nov 3, 2005 - 5:46 PM) i guess ill go for the pirelli then .. good to know hope they last longer then my kumho 711s [right][snapback]352721[/snapback][/right] My recommendation is to keep your rims for the winter and buy new rims with summer performance tires for the summer. No matter how good these performance allseasons are, they really just dont compare to summer tires. I am looking into a nice set of 16 x 8's and run 245/45/16 summer tires. That should help reduce the tire spin on a high powered FWD vehicle. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
| Lo-Fi Version | Time is now: September 14th, 2026 - 11:50 AM |
