> misfire, yarg
post Nov 1, 2005 - 8:42 PM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
Just wanted to see if anyone had any suggestions on my misfiring. it occures consistantly on acceleration except in higher rpm ranges (in which case is rockets forth like it normally does). i dumped some 44k ( fuel cleaner) and it got rid of the problem for a while then it came back once the tank was done. so i thought i should throw a fuel filter at it, no luck. im thinking maybe theres some kinda restriction at the pump or sticking injectors.. anyone else have the same problem?
Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..."
Replies (1 - 5)
post Nov 2, 2005 - 1:18 AM
dans_st
Joined May 24, '03
From Andrews TX
I'm guessing possibly ignition, my car used to do the same basically and I replaced cap,rotor, and wires and it worked just fine.
you can check if you have the manual for your car to see what resistance your wires should have, and that should help some with that
my second guess would be you ar erunning too rich and therefore you have a bog with a miss at lower RPM's
just my guess smile.gif ....
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Nov 2, 2005 - 9:52 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
My car does it too, but its more like backfiring. You should check your timing it might be off. If your like me though, you kinda get use too it and it somewhat sounds pretty cool with the bang at the back of the exhaust tongue.gif
post Nov 2, 2005 - 5:16 PM
Negative
Joined Apr 28, '04
From Houston, Texas
Could also be cheap gas. Mine will barely idle on 87 octane but runs like a champ on 93.
Not likely though. Most likely ignition (plugs, wires, our cap and rotor stinks too - I change mine out very often)
post Nov 3, 2005 - 12:23 AM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
i tried dumping in higher octane fuel and it started to run a little better. gas mileage is shot eitherway, so im leaning towards a fuel delivery problem as its not backfiring (no shooting noise, just stumbling as if its starved/running out of gas) but i should probably check it anyways..
Fred
post Nov 3, 2005 - 1:24 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I changed my fuel filter, it made the car run a lot better.
Live Free, Be Happy
Lo-Fi Version Time is now: June 10th, 2026 - 7:17 PM
