> misfire, yarg
post Nov 1, 2005 - 8:42 PM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
Just wanted to see if anyone had any suggestions on my misfiring. it occures consistantly on acceleration except in higher rpm ranges (in which case is rockets forth like it normally does). i dumped some 44k ( fuel cleaner) and it got rid of the problem for a while then it came back once the tank was done. so i thought i should throw a fuel filter at it, no luck. im thinking maybe theres some kinda restriction at the pump or sticking injectors.. anyone else have the same problem?
Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..."
Lo-Fi Version Time is now: June 10th, 2026 - 8:30 PM
