Nov 3, 2005 - 11:01 AM
Enthusiast ![]() ![]() Joined Feb 9, '03 From Sioux falls, South Dakota Currently Offline Reputation: 1 (100%) |
I know this has been covered before and i have searched but i can't get the search function to work right. i need to know, color, pin #, and connector for the speed signal and rpm on a 97 st. According to the how to on the afc the rpm is the 11th pin black an yellow but it doesnt say what direction to count from. if you count the way most manuals do it the 11th pin isnt black and yellow.anything will help thanks in advance.
-Aaron- -------------------- ![]() |
afroman turbo timer wiring Nov 3, 2005 - 11:01 AM
WannabeGT4 Did the picture he provided not explain it enough?... Nov 3, 2005 - 3:36 PM
afroman the only wire that is black/yellow would be in pin... Nov 3, 2005 - 6:58 PM
WannabeGT4 QUOTE(afroman @ Nov 3, 2005 - 5:58 PM)the onl... Nov 3, 2005 - 7:07 PM
afroman thanks so much. i took a chance and tapped the bl... Nov 3, 2005 - 7:35 PM
WannabeGT4 No problem. Anytime. Nov 3, 2005 - 7:40 PM
afroman looking at this it says that pin 11 on connector E... Nov 3, 2005 - 9:24 PM
WannabeGT4 That's for a manual transmision car. Don't... Nov 3, 2005 - 10:07 PM
WannabeGT4 any luck? Nov 4, 2005 - 11:19 AM
funnys_tears i got question too?
i try to put timer on my too... Jun 28, 2007 - 1:07 PM
lagos you should make things easy and just buy a harness... Jun 28, 2007 - 1:36 PM
Kadett QUOTE(lagos @ Jun 28, 2007 - 8:36 PM... Jun 28, 2007 - 1:58 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 3:47 AM |
