> oil system, what can I do?
post Nov 6, 2005 - 11:00 PM
dans_st
Joined May 24, '03
From Andrews TX
I have read alot about turbo engines and common problems and one thing that I have seen alot oil systems not producing a steady supply of oil on turbo engines(N/A as well I'm sure) that are making alot more power than what they were designed to.
And or lack oil in the high RPM range resulting in spinning rod bearings.
I already have an oil cooler and the relocated oil filter(I know relocation doesn't help). Is there anything else I can do to imrove the factory oil system?
(1)would a larger capacity oil pan help?
(2)is there a larger volume oil pump for our cars?
(3)can I use a DRY sump oil system?, are there any available
I know I probably am not exeding the limit of my factory system yet, but I am trying to plan ahead and have the safest most efficient engine I can have- So any help would be appreciated
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
- dans_st   oil system   Nov 6, 2005 - 11:00 PM
- - Dr_Tweak   Typically it's not a problem with our engines,...   Nov 6, 2005 - 11:13 PM
- - lagos   there really isint an oiling problem with the moto...   Nov 7, 2005 - 1:53 AM
- - nik   oil squirters from a 4ag if you want extra interna...   Nov 7, 2005 - 7:08 PM
- - dans_st   QUOTEnik Posted Today, 05:08 PM   oil squirt...   Nov 7, 2005 - 10:50 PM
|- - Dr_Tweak   QUOTE(dans_st @ Nov 8, 2005 - 3:50 AM)QUOTEni...   Nov 7, 2005 - 11:39 PM
- - nik   THE DOC is right even with the amount of boost i w...   Nov 8, 2005 - 11:59 AM
- - dans_st   your right I don't really need it- I was just ...   Nov 9, 2005 - 1:01 AM
- - pxcr440   i havent seen many problems with the 7a but i have...   Nov 14, 2005 - 2:34 PM
- - Punch   only oil upgrade u should get is a oil cooler, any...   Nov 26, 2005 - 5:20 AM
|- - Batman722   QUOTE(Punch @ Nov 26, 2005 - 5:20 AM...   Nov 26, 2005 - 3:55 PM
- - blackthunder   pxcr440..any tips on how to solve that problem wit...   Nov 28, 2005 - 2:58 AM
|- - trd94   QUOTE(blackthunder @ Nov 28, 2005 - 2...   Nov 29, 2005 - 2:29 AM
- - epinasty   Anyone have details on an oil cooler for the 5sfe?...   Nov 28, 2005 - 5:49 PM
|- - Batman722   QUOTE(epinasty @ Nov 28, 2005 - 5:49...   Nov 28, 2005 - 5:53 PM
- - dans_st   QUOTEtrd94 Posted Today, 01:29 AM QUOTE(blackth...   Nov 29, 2005 - 10:55 PM
|- - trd94   QUOTE(dans_st @ Nov 29, 2005 - 10:55...   Dec 1, 2005 - 12:06 PM
- - blackthunder   sweet...ill def keep you in mind. (cause i doubt ...   Dec 1, 2005 - 1:55 AM
|- - trd94   QUOTE(blackthunder @ Dec 1, 2005 - 1...   Dec 1, 2005 - 12:10 PM
- - nik   i got some real nice ones for 7agte edit : good ...   Dec 1, 2005 - 12:09 PM
- - White 2.5rs   umm, dont piston squirters only cool the piston? d...   Dec 1, 2005 - 1:15 PM
Lo-Fi Version Time is now: June 24th, 2026 - 2:44 PM
