Nov 14, 2005 - 2:49 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
hi all,
jus bought some guage..and troubled on how to install them...any help ?..i kno the lighting can be routed to the ash n cig lighter..how bout the others? -------------------- ![]() |
Nov 15, 2005 - 11:00 PM
voltemeter has three wires (red, black, orange), air/fuel ratio guage has 4 (red, black, orange, green)...i read the directions and it jus shows pictures.....the unstructions for the air/fuel ratio guage says one goes to the 02 sensor sender?....some1 plz help!?!?!?!!?!?!?!
Nov 16, 2005 - 3:30 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Seattle, WA Currently Offline Reputation: 0 (0%) |
what brand gauges do you have?? that might help decode the wires. But based on what youve said, id would guess:
red: swtich on 12 v power black: common ground orange: dash light power for lighting green: connection to the sender this is just a guess, since i dont know what brand you have -------------------- Its Orville's Celica, i just drive it... |
Nov 16, 2005 - 4:37 PM
im using toms motorsport guages..yea ur right on the color of wires....ive gotten a post from negative and now i know how to route the signal wires...if im not mistaken i can disconnect the o2 harness n plug it in with the connectors right?...
now im ready but if tehres anything i might need to do b4 i F8K everything up, can ya lemme kno?... thanx in advance -------------------- ![]() |
Nov 17, 2005 - 11:48 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
QUOTE(DeW_H0e_GT @ Nov 16, 2005 - 9:37 PM) [snapback]356374[/snapback] im using toms motorsport guages..yea ur right on the color of wires....ive gotten a post from negative and now i know how to route the signal wires...if im not mistaken i can disconnect the o2 harness n plug it in with the connectors right?... now im ready but if tehres anything i might need to do b4 i F8K everything up, can ya lemme kno?... thanx in advance Thanks for the mention. I stress that you do use the method I discussed - if you splice into the o2 sensor wires you will cause problems because you change the resistance - that's how those signals work. Just plug it into the connector between the o2 wires and the wiring harness - done. Peice of cake. I could take a pic for you but I don't have anyway to host it. Edit - just noticed you are OBDI - you should only have two wires on your one (not two) o2 sensor. Should make things easier for you. If I'm correct on this and I'm not 100% because I'm OBDII. This post has been edited by Negative: Nov 17, 2005 - 11:50 AM -------------------- ![]() |
Nov 17, 2005 - 9:53 PM
if you dont mind can u send a pic to my email addy: spoonxeg@hotmail.com
working on it the whole night...and couldnt get it to work...i've tried all three wires on the 02 sensors connectors and all of those isnt even givin it a signal..plz help -------------------- ![]() |
Nov 18, 2005 - 10:03 AM
QUOTE(DeW_H0e_GT @ Nov 18, 2005 - 2:53 AM) [snapback]356833[/snapback] if you dont mind can u send a pic to my email addy: spoonxeg@hotmail.com working on it the whole night...and couldnt get it to work...i've tried all three wires on the 02 sensors connectors and all of those isnt even givin it a signal..plz help From the PM you sent me it seems you got it now. If you still need the pic PM me again. -------------------- ![]() |
| Lo-Fi Version | Time is now: September 15th, 2026 - 2:28 AM |
