Nov 16, 2005 - 5:50 PM
Enthusiast ![]() Joined Oct 7, '05 From Kansas Currently Offline Reputation: 0 (0%) |
Since it seems I should get bigger injectors than the good ole' n/a supra injectors,
I was wanting to know what injectors are available. Can you put any injector made for the 3sgte in the 5sfe? Is there a good car to get 400cc+ injectors off of? How big should I get with the goal of getting maybe 190-200whp. |
Nov 17, 2005 - 12:49 AM
Enthusiast ![]() ![]() Joined Jan 16, '04 From sydney australia Currently Offline Reputation: 0 (0%) |
I used 4agze red injectors and got 200whp....but i also had a standalone.
-------------------- ![]() 312whp with more to come.... |
Nov 17, 2005 - 12:59 AM
Enthusiast ![]() Joined Nov 6, '04 Currently Offline Reputation: 0 (0%) |
use the rx-7 460cc injectors
Nov 17, 2005 - 6:43 AM
QUOTE(ummmx2 @ Nov 17, 2005 - 12:59 AM) [snapback]356521[/snapback] use the rx-7 460cc injectors agreed. read the turbo sticky, all the info for them is there. -------------------- Former Team 5SFTE pro member ;)
Nov 17, 2005 - 12:24 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) |
yea. use the rx7 460cc injectors. top feed high impendance. out from the 88 - 91 S5 rx7s.
here's pic of mine. this is how the injectors looks like
Nov 17, 2005 - 5:15 PM
Enthusiast ![]() ![]() Joined Jan 17, '03 From Fresno, CA Currently Offline Reputation: 0 (0%) |
well those directly fit into the stock or have to be modify
Nov 17, 2005 - 5:35 PM
QUOTE(st202gt @ Nov 17, 2005 - 5:15 PM) [snapback]356724[/snapback] well those directly fit into the stock or have to be modify they are plug and play -------------------- Former Team 5SFTE pro member ;)
Nov 20, 2005 - 4:26 PM
Very nice thanks a lot guys. I'll go after those for sure.
Must be the high impedence huh..? This post has been edited by epinasty: Nov 20, 2005 - 4:55 PM |
Nov 20, 2005 - 8:26 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 25, '03 From Miami, FL Currently Offline Reputation: 9 (100%) |
QUOTE(epinasty @ Nov 20, 2005 - 2:26 PM) [snapback]357581[/snapback] Very nice thanks a lot guys. I'll go after those for sure. Yes sir. High impedance(saturated).Must be the high impedence huh..? -------------------- ![]() |
Nov 20, 2005 - 10:16 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
QUOTE(ummmx2 @ Nov 17, 2005 - 5:59 AM) [snapback]356521[/snapback] use the rx-7 460cc injectors i know a guy selling them |
Nov 21, 2005 - 7:12 PM
how much?
Nov 21, 2005 - 8:30 PM
Enthusiast ![]() Joined Oct 21, '05 From Okinawa, Japan Currently Offline Reputation: 0 (0%) |
EDIT: nevermind...the ones i just got were the 1350 and not the 2010. compatible or no?
This post has been edited by blackthunder: Nov 21, 2005 - 8:34 PM -------------------- -Dan
1998 SSII Beams, work in progress... |
Nov 21, 2005 - 9:02 PM
QUOTE(blackthunder @ Nov 21, 2005 - 8:30 PM) [snapback]358126[/snapback] EDIT: nevermind...the ones i just got were the 1350 and not the 2010. compatible or no? the 1350 ones will not work this is the PT # of the ones were using 195500-2010 -------------------- Former Team 5SFTE pro member ;)
Nov 21, 2005 - 9:56 PM
QUOTE(JoKeRkId613 @ Nov 22, 2005 - 12:12 AM) [snapback]358069[/snapback] how much? if ur stilll intrested pm ill ask him |
Nov 22, 2005 - 2:30 AM
damn! well they will be up on ebay soon then i guess. poop!
Nov 22, 2005 - 10:59 AM
the 1350 may look the same but they're low impendance. you need the 2010 that's high impendance
| Lo-Fi Version | Time is now: July 30th, 2026 - 9:23 AM |
