Nov 24, 2005 - 2:25 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 25, '03 From Miami, FL Currently Offline Reputation: 9 (100%) |
Hi. I'm trying to ground my brother's parking brake wire so that he can have his AVIC-D1 play movies and stuff while driving. Where is the parking brake wire? Thanks.
EDIT: I know there's laws and stuff and you shouldn't watch movies while driving or whatever but don't worry about us. We're willing to take that risk. This post has been edited by JoKeRkId613: Nov 24, 2005 - 6:43 PM -------------------- ![]() |
Nov 24, 2005 - 7:02 PM
in the celica, its RIGHT BY THE HANDLE
Nov 24, 2005 - 7:16 PM
perfect. thats what i was thinking. now lets see if it's the same in the tC. lol. thanks manny.
Nov 24, 2005 - 9:31 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
The light green wire goes to ground. You don't need to mess with the parking brake at all. Just ground that wire or if you want you can hook it up to a switch that completes the circuit to ground.
This post has been edited by WannabeGT4: Nov 24, 2005 - 9:33 PM -------------------- ![]() Project ST204.5 99.88946% complete... |
Nov 24, 2005 - 10:21 PM
Ok. Yeah, I took a look at the back of the navi and I found that I didn't have to mess with the e-brake. It all has to do with the back of the thing. It appears to me that the light green wire is already grounded... The spliced it into a black wire that goes from the plug of the navi to some little black box there... but there's 2 black wires coming from the navi plug. I'm guessing they're both grounds? So I guess that there is fine... Or should I disconnect the light green from the black wire and ground it by itself? I have to do that and I also have to ground some other wire there. Random and probably dumb question... Can you ground 2 wires to the same ground?(Like if I'm grounding it to a bolt that is good ground, can I ground both wires to the same bolt? Thanks.
Nov 24, 2005 - 10:34 PM
There is no problem connecting more than one wire to the same ground, however, when I do harnesses like this I try not to have any extra wires to screw into stuff so that it's always plug and play. Just undo whatever the previous person had done with the light green wire and tap into the same ground wire that the system uses.
| Lo-Fi Version | Time is now: August 11th, 2026 - 3:20 PM |
