Nov 27, 2005 - 3:17 PM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From Corpus Christi Tx Currently Offline Reputation: 5 (100%) |
probly sounds stupid. but how can you tell if its dual entry. Also what are the benefits over..... I guess you could say a standard ct-26
Also shin, if you read this, what turbo do you have? |
Nov 27, 2005 - 4:30 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Google is your friend
![]() QUOTE Garrett twin-entry turbine turbocharger. This design can be effective at improving spooling performance by increasing exhaust energy at low RPM on engines with fewer cylinders by isolating the exhaust pulses from adjacent combustion events until they actually contact the turbine wheel. ...and... http://www.alltrac.net/tuning/turbofaq.html Gary This post has been edited by GT4WRC: Nov 27, 2005 - 4:32 PM -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Nov 27, 2005 - 4:43 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jul 5, '05 From Arlington, TX Currently Offline Reputation: 2 (100%) |
saw this website while doing a google search --
very imformative http://www.mrcontrols.com/primers/turbo.htm below is small piece of info from the site At the current time, my suggestion for a twin entry CT-26 upgrade is to add a TO4E-46 trim compressor wheel and perform a 15 degree clip on the turbine wheel. Those who have ceramic turbine wheels (only used in Japanese spec 3S-GTEs) cannot clip due to the brittleness of the material, but the smaller ceramic turbine is already a little less restrictive than the metal one and naturally supports about 10 rwhp more that its unclipped sibling. For all out performance, there is a CT-26/35R drop-in hybrid available from Extremeboost which couples a low-friction ball bearing central assembly and large GT35R turbine housing with an A/R of 0.85 (the stock CT-26 turbine housing has an A/R of 0.49) and a 56-trim compressor wheel. I have not yet seen a dyno chart of this hybrid turbocharger in action but it should be able to produce well over 300rwhp on a 3S-GTE. In fact, it may even require a complete fuel system upgrade to safely run at higher boost levels on the MR2 CT26/35R Roller Bearing Turbo (400hp) Modified CT26 Compressor (56 Trim) .70 A/R Modified Stock Turbine Housing (84 Trim) .85 A/R 44 lbs/min (Drop In Replacement) eXtremeBoost Retail: $ Email Me ![]()
This post has been edited by celicarus: Nov 27, 2005 - 4:52 PM |
Nov 27, 2005 - 4:49 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
Ahhhh! I remember a technician telling me about the dual entry turbos.
Its really good and very helpful for those 4 cylinder engines. The first turbo is the primary one, its small so that it can pick up fast and spool the second turbo, a larger turbo that doesn't spool as fast as the primary turbo. while both turbos in one spin, the small one provides the power that is not present in the bigger one, then when the big one kicks in it sucks up most of the air and the smaller one kinda goes into a regular stand by spin. This setup is kinda like the Dual Supercharged Turbo setup. The supercharger blows air into the turbo to make it spool up faster. If U think about it, its a pretty good way of getting fast pickups for a turbo the size of an oil barrell. |
Thanks alot, I believe I found what I was looking for, its just alot people selling them dont say weather theyre single or dual. thank again
Nov 27, 2005 - 5:03 PM
![]() Enthusiast ![]() Joined Jun 6, '05 From Texas/Hawaii Currently Offline Reputation: 0 (0%) |
wat are the ups and downs on a dual turbo seems to be perfect if ya gonna get a turbo. mabye the price? i dont kno. first time hearin bout em.
-------------------- I gotz 2 things my celi and a dream, the prob is commin up with the thrid one...
Nov 27, 2005 - 5:09 PM
it is already dual entry for a ct-26
CT-26 Twin Entry Turbocharger The stock CT-26 twin entry turbocharger in the 3S-GTE correct me if i'm wrong any one This post has been edited by celicarus: Nov 27, 2005 - 5:10 PM |
Nov 27, 2005 - 5:19 PM
^^^well it says in the alltrack sight that the dual entry is only in the 90-93 All Trac and 91+ MR2
Nov 27, 2005 - 5:23 PM
so basicly, the dual entry has the 3 mounting points underneath the turbo (if your just looking at a picture of one)??
Nov 27, 2005 - 5:39 PM
QUOTE(celicaGT96 @ Nov 27, 2005 - 4:23 PM) [snapback]360146[/snapback] so basicly, the dual entry has the 3 mounting points underneath the turbo (if your just looking at a picture of one)?? i guess that would be correct since my information was related to mr2's -- but don't know about the 3 mounting points stuff |
Nov 27, 2005 - 8:29 PM
Enthusiast ![]() ![]() Joined Feb 9, '03 From Sioux falls, South Dakota Currently Offline Reputation: 1 (100%) |
most of these comments confuse the **** out of me. a ct-26 off a 5th gen altrac and the 2nd gen mr2 will be twin entry. it means on the turbine housing where the exhaust will enter the turbo there are two inlets not one big opening. look at this page and it is the second thing explained.
This post has been edited by afroman: Nov 27, 2005 - 8:30 PM -------------------- ![]() |
Nov 27, 2005 - 11:20 PM
ST205 also uses a dual entry turbo.
Gary This post has been edited by GT4WRC: Nov 28, 2005 - 4:05 AM -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) |
i have the ct26 dual entry.
Nov 27, 2005 - 11:38 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
I got mine of e-bay...
Nov 28, 2005 - 4:30 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 25, '03 From Miami, FL Currently Offline Reputation: 9 (100%) |
dumb question, but what type of flange would i need for a ct-26 turbo? i want the twin(dual) entry from the st205. the flange i have now is for a t3t4. im either going with a t3 or the ct26. and probably an even dumber question. can you use the same flange for a ct27. thanks/
Nov 28, 2005 - 6:11 PM
the ct26 dual entry gasket you mean? if that's wat you mean. the ct26 and ct27 have the same gasket since the ct27 is basically an upgraded version of the ct26
Nov 28, 2005 - 6:32 PM
no, on the 3s-gte manifold, theres a flange. the part where the manifold connects to the turbo. on the 3s mani, it should have 2 openings for the dual entry. that little plate with the openings on the manifold. what type of flange is that? is it only for the ct26?(assuming the flange is called a ct26 flange, right?) because the one on my manifold is to go on my 7a and the flange is for a t3t4. i was just told that a t3t4 is kinda big for a 7a and almost everyone goes with a t3. so i either want to put a t3 on there or a ct26. meaning i would have to cut and weld a new flange on to fit those turbos... so the question is, whats the name of the flange that goes on the ct26? thanks.
Nov 29, 2005 - 2:15 AM
Enthusiast ![]() Joined Oct 21, '05 From Okinawa, Japan Currently Offline Reputation: 0 (0%) |
kind of off topic but someone who doesnt have a ct26 dual entry installed give me the the measurements of the mouting holes? is it square? i need the lenth and widths from hole to hole, thanks!
-------------------- -Dan
1998 SSII Beams, work in progress... |
Nov 29, 2005 - 8:14 AM
QUOTE(JoKeRkId613 @ Nov 28, 2005 - 6:32 PM) [snapback]360693[/snapback] no, on the 3s-gte manifold, theres a flange. the part where the manifold connects to the turbo. on the 3s mani, it should have 2 openings for the dual entry. that little plate with the openings on the manifold. what type of flange is that? is it only for the ct26?(assuming the flange is called a ct26 flange, right?) because the one on my manifold is to go on my 7a and the flange is for a t3t4. i was just told that a t3t4 is kinda big for a 7a and almost everyone goes with a t3. so i either want to put a t3 on there or a ct26. meaning i would have to cut and weld a new flange on to fit those turbos... so the question is, whats the name of the flange that goes on the ct26? thanks. joker, your flange will either br a T3 or a T4...theres no such thing as a t3/4 flange. more than likley, its a T3 flange, and in your case, with the 7a, i'd be looking for a T3..what is it dan...50trim? just for future refrence, when you see t3/4...basicly what it means is its a hybrid turbo, with a t4 compressor side/wheel with a t3 exhuast housing. This post has been edited by presure2: Nov 29, 2005 - 8:16 AM -------------------- Former Team 5SFTE pro member ;)
Nov 30, 2005 - 3:19 PM
Enthusiast ![]() ![]() ![]() Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) |
soulshadow - thats the definition of twin-turbo setup. MKIV Supra, 300Z....
Duel entry turbo's (or twin entry) have a divided housing to better utilize the exhaust gases and eliminate back pressure. In order for it to have any effect, the exhaust manifold must also be setup to isolate the runners (or at least the cylinder pairs) until they reach the turbo. The stock 3SGTE manifold does this, and I know the turbonetics 3SGTE manifold does too. If your manifold is one of the log designs, with one big collector that all the runners join at, then a duel entry will have no effect. JoKeRkId613 - Its a CT26 flange. Kinda hard to find, I ended up having one cut cut using the gasket as a template. Its almost a sideways T4. -------------------- Scott
West Michigan |
| Lo-Fi Version | Time is now: June 24th, 2026 - 5:48 PM |
