Dec 2, 2005 - 6:04 PM
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
i think if u go turbo you will encounter a ton of problems. do more research.
Dec 2, 2005 - 6:08 PM
i have did alot of research and on this site there is alot of ppl with stock internals with turbos, so maybe some more help from ppl would be kewl
Dec 2, 2005 - 7:06 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
first off start here http://www.6gc.net/index.php?action=howto&itu=128
1. what kind of turbo should i get with a stock 7a? garrett t3 2. Where can i get the oil pan i need?use your stock one can i get this at a junk yard? yes 3. Where can i get the turbo manifold thing? jgstools.com can i get it at a junkyard? no 4. what kind of intercooler should i get?check ebay and where can i get the piping for it? i have some or summit racing etc 5. Are the new injectors a must or can they wait for a little while? depends on boost under and turbo size t3 under 6-7 stock is fine over i would look into new ones 6. Do u have to change the head? NO 7. what else would i need? check the how to and how much do you think all of this would cost for everything even the stuff i get from a junkyard. $1000-$2000 and what kind of cars can i get the turbo i need off of. do research that a big question What kind of power do you think this will give me?check the how to there are dyno numbers in there like what time in a quarter mile? ???? maybe 15 or so just depends -------------------- yea your 3sgte is cool but ill stick to my 7agte
Dec 2, 2005 - 8:55 PM
http://www.6gc.net/forums/index.php?showtopic=28068
read that as well to understand what turbo you should get where to get wat and wat you should be running |
| Lo-Fi Version | Time is now: August 30th, 2026 - 9:17 PM |
