Oct 8, 2005 - 10:57 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
OK here goes.
I hooked mine up to a 3sgteRC. Not sure if the 7a and 5s are the same. The unit has three wires. Black, Red, Green(in mycase) Black goes to ground. The red goes to positve, like the cig lighter. Green or signal wire connects to the solid black wire on your ignitor in the engine bay. After ur done you should have something like this ![]() The end DEF -------------------- ![]() I will return one day. |
Oct 8, 2005 - 11:39 PM
what shift light did you get?
im pretty sure that one of the wires on the ignitor is what sends out the rpm signal to the ecu. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Oct 8, 2005 - 11:53 PM
i THINK the black wire goes directly from the ignitor to your tach.. so if you splice into that, it should work.
Oct 9, 2005 - 2:18 AM
The signal wire does go to your RPM signal(tach) wire, which can be tested for with a multimeter.
To ensure that you're finding the right wire, set your multimeter in AC mode and probe wires while revving the engine. The RPM signal wire gives a low voltage that rises(but still stays under 10 volts I think...can't remember for sure though) as the RPM rises. -------------------- New Toyota project coming soon...
Dec 4, 2005 - 12:16 AM
Enthusiast ![]() Joined Dec 1, '05 From South Windsor, CT Currently Offline Reputation: 0 (0%) |
I'm obviously a n00b so you may think this is a dumb question...
Someone please enlighten me.... i crave knowledge What purpose does a shift light actually serve? Does it just tell you when you should shift gears? If so, do you really need a light for that?? I've been driving stick for 10 years so i wouldnt need a light to tell me when to shift. What are the pros/cons?? -------------------- |
Dec 4, 2005 - 4:21 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
QUOTE(djultimate @ Dec 3, 2005 - 11:16 PM) [snapback]363075[/snapback] I'm obviously a n00b so you may think this is a dumb question... Someone please enlighten me.... i crave knowledge What purpose does a shift light actually serve? Does it just tell you when you should shift gears? If so, do you really need a light for that?? I've been driving stick for 10 years so i wouldnt need a light to tell me when to shift. What are the pros/cons?? lol I kind of agree. I don't think I would ever put a shift light in my car, I don't need it to tell me when to shift -------------------- 1999 Celica GT
Dec 4, 2005 - 4:45 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) |
Yeah, you don't need a light if it takes your car a while to get from shift point to shift point. If it jumps faster, it's good to have. And for these guys running turbo set up especially, it's kind of a warning light that the rpm's are too high and they need to shift. If your doing autocross or something, you can't look at the rpm gauge all the time, so it's good to have a light you can see out of the corner of your eye that lets you know to shift. I doubt I'll ever need a shift light with my 5sfe, but if I put a 3sgte, 3sge, or 4age in my car, I'd want one for safety.
Dec 4, 2005 - 9:35 PM
This is exactly why I have a shift light. When involved in a race, I dont want to look down to watch the tach. So this light does it for me. At my designated shift point the light hits, and I shift.
The shift points are very quick for the turbo guys. I love this light, I can keep my eye on the road and not have to look down. DEF -------------------- ![]() I will return one day. |
Dec 4, 2005 - 10:48 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
This post has been edited by 97lestyousay: Apr 5, 2012 - 5:07 PM -------------------- JDM guy made me do it.
Dec 5, 2005 - 1:37 AM
QUOTE(Bigmeanbulldog55 @ Dec 4, 2005 - 4:45 PM) [snapback]363194[/snapback] for these guys running turbo set up especially, it's kind of a warning light that the rpm's are too high and they need to shift. If your doing autocross or something, you can't look at the rpm gauge all the time, so it's good to have a light you can see out of the corner of your eye that lets you know to shift. ooohhhhh, now i get it... that makes sense. pretty good idea. -------------------- |
Dec 5, 2005 - 1:43 AM
Glad to help DJ, Its a very helpful tool when the throttle is floored.
Sep 11, 2006 - 4:01 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
I'd just like to let u know that if I ever install one of these shift lights, and set it to 5, 6K....
I don't expect my light to ever go on in my life time. -------------------- |
Jul 26, 2008 - 1:29 PM
Enthusiast ![]() Joined Jul 2, '08 From Midlands, UK Currently Offline Reputation: 0 (0%) |
more like 7k, just off the redline, 65mph in 2nd hehe
Jun 11, 2010 - 11:59 AM
Enthusiast Joined Jun 11, '10 From Brazil Currently Offline Reputation: 0 (0%) |
Hello,
I have a question about the instalation, where did you pulled the signal wire?? |
Jun 11, 2010 - 4:15 PM
Black goes to ground. The red goes to positve, like the cig lighter. Green or signal wire connects to the solid black wire on your ignitor in the engine bay. Hello, I have a question about the instalation, where did you pulled the signal wire?? -------------------- |
Jun 12, 2010 - 12:54 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 10, '08 From sweet home, OR Currently Offline Reputation: 3 (100%) |
or a simpler shift light and a lil more useful
a stri sequential shift light plugs straight into a cigarette lighter using a 12v signal and is still very accurate no tach wire or anything just plug and play you set a low and high like me personally have the low(so the first led comes on) at 4k and set the last led too just about 5.5k ill make a write up soon http://www.importpartspro.com/esi-comp.html http://www.6gc.net/photo/member/10052/4 here it is in my car the unit itself is in the middle of the steering wheel and the control box is were the clock should be This post has been edited by terbear4god4life: Jun 12, 2010 - 12:57 PM -------------------- |
Jun 17, 2010 - 4:23 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Black goes to ground. The red goes to positve, like the cig lighter. Green or signal wire connects to the solid black wire on your ignitor in the engine bay. Would it be possible to hook up/splice the signal wire directly into the tach wire at the back of the speedo cluster? -------------------- |
| Lo-Fi Version | Time is now: September 15th, 2026 - 11:53 PM |
