> A Rant to Wheel/Suspension Shops, Too much torquing wheels
post Dec 6, 2005 - 11:29 PM
Celicav
From Virginia
Well, I recently wanted to switch the wheels between the two 6gcs I currently own, and decided I was going to try and do it myself. I have actually never tried to take a wheel off a car before (I am 29, and somehow never have gotten a flat, and new to working on cars), so I went out and bought a jack, jack stands, and all that crap. Well, I go to try to take the first lug nut off the wheel, and it will not come off for the life of me...then a second, and a third, etc, and none would budge. Granted I was using the spare tire wrench, which is only like a foot long, but I was standing on the wrench, pulling up on it as hard as possible. Now, I am not the strongest or heaviest guy in the world (about 165 lbs), but I am in shape and fairly strong.
I think I was having no success, b/c I previously got the wheels serviced at Sears, and I think they are over torqueing them b/c they use those damn impact wrenches. I learned that you are only supposed to put like 80 ft/lbs of torque down when tightening the lugs on Celicas, or ANY Toyota CAR, and you should only tighten lugs down BY HAND. I know, I know, these shops use the guns in the interest of time...but this makes it impossible for a lot of people to change their own tire on the side of the road if they don't have a breaker bar or something. Plus, I read that over torque can do damage like to the lugs, wheels, etc. You know what I mean?
By the way, does anyone know the wheel bolt diamater on our wheels (inches/mm)? And, does a good size breaker bar usually solve the stubborn lug issue? I guess with the extra inches on the bar, you have to put down less pounds when turning. Thanks.
This post has been edited by Celicav: Dec 6, 2005 - 11:45 PM
post Dec 6, 2005 - 11:41 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
breaker bars do help. an Impact wrench would be better but thats an air tool. And at the shop (discount tires) we take the wheel on and off with an impact gun and after the car is done, we torque it at the recommended amout of lbs. its too make sure the wheel doesnt come flying off.
This post has been edited by BLINKYxMUNKEY: Dec 6, 2005 - 11:42 PM
FlickR
post Dec 6, 2005 - 11:51 PM
Celicav
From Virginia
QUOTE(BLINKYxMUNKEY @ Dec 6, 2005 - 9:41 PM) [snapback]364243[/snapback]
Are you saying that you are using the gun only to thread the lug on only till it becomes flush against the wheel circle, then you torque it (tighten it) by hand with a torque wrench?
post Dec 6, 2005 - 11:55 PM
Benevolence
Joined Oct 9, '02
From San Diego, CA
righty tighty lefty loosey tongue.gif j/k
post Dec 7, 2005 - 12:00 AM
Celicav
From Virginia
QUOTE(Benevolence @ Dec 6, 2005 - 9:55 PM) [snapback]364255[/snapback]
post Dec 7, 2005 - 1:44 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
post Dec 7, 2005 - 1:56 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I'm a fairly big guy, and I've ran into problems getting wheels off after taking the car to a shop to get new tires put on. I've been working on cars ever since I could walk, so that definately not a problem. You'll want to buy a better wrench. I tried that little stock piece of crap one time, then I bought a real wrench.
Live Free, Be Happy
post Dec 7, 2005 - 2:50 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I <3 breaker bars and impact tools.. Wish I could afford a compressor and some tools though.. frown.gif
**** Photobucket
post Dec 7, 2005 - 11:57 AM
crismillencolin
Joined Nov 25, '05
From Glasgow
QUOTE(Benevolence @ Dec 6, 2005 - 11:55 PM) [snapback]364255[/snapback]
351.5bhp RWD TT
post Dec 7, 2005 - 12:58 PM
Verde97
Joined Aug 20, '03
From Kansas City
I've ran into this problem before, too.
You are correct when you said that Toyota's need 80 ft/lbs of torque. They need NO MORE. Sears used an impact gun to torque your wheels. A lot of places do this, unfortunately.
A 4-way may do the trick to get them off, but not likely. What I would do: take your car to Sam's Club. They are REQUIRED to use torque wrenches on their impact guns so that the wheels are torqued the right amount. By doing this, you will also be able to get your existing wheels off.
By overtorqueing, the studs can be severely damaged, and possibly break off when the wheels are being taken off again.
Hope this helps...
post Dec 8, 2005 - 9:48 AM
BLINKYxMUNKEY
Joined Nov 12, '03
QUOTE(Celicav @ Dec 6, 2005 - 11:51 PM) [snapback]364250[/snapback]
pretty much, yea.
FlickR
post Dec 9, 2005 - 12:57 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
break the stud and replace... ;]
Lo-Fi Version Time is now: August 30th, 2026 - 12:05 AM
