Dec 14, 2005 - 11:09 PM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From Corpus Christi Tx Currently Offline Reputation: 5 (100%) |
has anyone tried to rebuild their ct26???
Im planning on getting a turbo soon, and wanted to rebuild it with a rebuild kit from I forgot what site. I know its not recommended, but I really dont want to pay all that money to have it rebuilt. The main thing Im concered about is the balancing. Can it be built by me, and then taken somewhere to be balanced, or does balancing just consist of actually lineing everything up during the rebuilding process? Also please dont suggest a pre-built turbo because of other reasons that dont matter. Just so some of you know, NO I have never done anything like this, but I do have a rather good understanding of mechanical work, and things of that nature. any help or advice would be great.... |
Dec 15, 2005 - 5:53 AM
i did it with a t3 turbo with a kit i got off of ebay
would i do it again? no there is more to rebuilding a turbo than just replacing the oil seals and bushings(usually the whole center cartridge is replaced with a rebuilt core). it didnt last too much longer after the rebuild. for a little bit it didnt burn oil, but it got worse and worse every day. i ended up just buying a new turbo after spending like $100 on a rebuild kit plus my time and down time with the car and i know you dont want to hear it but if you wanna get cheap with the turbo, you might as well give up now because turboing your car will nickel and dime you to death. unless you spend good money, or really know what you are doing and shop around for a long time, you will have problems left and right when you go the cheap route which will only end up costing you the money you saved. do things right the first time. it saves a lot of time, money, and heartache -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Dec 15, 2005 - 6:55 PM
QUOTE and i know you dont want to hear it but if you wanna get cheap with the turbo, you might as well give up now because turboing your car will nickel and dime you to death. unless you spend good money, or really know what you are doing and shop around for a long time, you will have problems left and right when you go the cheap route which will only end up costing you the money you saved. man speaks the truth ! -------------------- 15PSI - 30MPG - Megasquirt Tuned
Dec 16, 2005 - 8:06 AM
QUOTE(97sccelica @ Dec 15, 2005 - 5:53 AM) [snapback]367499[/snapback] i did it with a t3 turbo with a kit i got off of ebay would i do it again? no there is more to rebuilding a turbo than just replacing the oil seals and bushings(usually the whole center cartridge is replaced with a rebuilt core). it didnt last too much longer after the rebuild. for a little bit it didnt burn oil, but it got worse and worse every day. i ended up just buying a new turbo after spending like $100 on a rebuild kit plus my time and down time with the car and i know you dont want to hear it but if you wanna get cheap with the turbo, you might as well give up now because turboing your car will nickel and dime you to death. unless you spend good money, or really know what you are doing and shop around for a long time, you will have problems left and right when you go the cheap route which will only end up costing you the money you saved. do things right the first time. it saves a lot of time, money, and heartache read those last two paragraphs OVER AND OVER, till your head hurts. really hit the nail on the head with that one. -------------------- Former Team 5SFTE pro member ;)
Dec 24, 2005 - 11:00 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
I rebuilt mine TWICE in less than 500 miles...it's that damn oil pressure. I need the oil restrictor bad. Anyway, the rebuild is easy but like they said, do things right the first time.
| Lo-Fi Version | Time is now: August 27th, 2026 - 7:47 PM |
