> 3sgte died..., Cut out on me...??
post Dec 16, 2005 - 7:44 AM
Celica_At_GT
Joined Sep 21, '02
From Melbourne, FL
Well here is a little history first (since haven't posted on this board much - use to a lot on cnet (celica.net) back in the day though....
I had done a 3sgte engine swap and had a buddy do all the wiring for me (about 3 years ago). After finishing the mechanical stuff and putting th engine in, I found out the wiring was hosed. I took it to a shop to get it looked at and they put a microtech standalone ecu in it.
I finally got it running and it ran great for about 2 hours of usage and then just died on me. I haven't been able to restart it since then (but haven't been working on it too much)...
The pistons all seem to have really low compression (all around 90-100 psi). I am wondering if
1. what the compression should be.
2. if it is low, why is it low on all of the cylinders - does this mean the head gasket may have been put on wrong?? What could this imply?
Thanks for any assistance.
Ben
- Celica_At_GT   3sgte died...   Dec 16, 2005 - 7:44 AM
- - presure2   well, as for the compression #'s, if the motor...   Dec 16, 2005 - 8:04 AM
|- - Celica_At_GT   QUOTE(presure2 @ Dec 16, 2005 - 6:04...   Dec 16, 2005 - 8:12 AM
- - defgeph   Check for vacume leaks, check your fuses, double c...   Dec 16, 2005 - 9:34 AM
- - Celica_At_GT   So I shouldn't worry about those compression n...   Dec 16, 2005 - 9:49 AM
- - defgeph   Check the sensors yourself, dont trust the standal...   Dec 16, 2005 - 9:56 AM
|- - Celica_At_GT   QUOTE(defgeph @ Dec 16, 2005 - 7:56 ...   Dec 16, 2005 - 10:28 AM
- - lagos   compression should be around 164 or more. try doi...   Dec 16, 2005 - 2:48 PM
|- - Celica_At_GT   QUOTE(lagos @ Dec 16, 2005 - 12:48 P...   Dec 16, 2005 - 3:41 PM
- - lagos   well... if you are getting spark and fuel, then ch...   Dec 16, 2005 - 3:57 PM
|- - Celica_At_GT   QUOTE(lagos @ Dec 16, 2005 - 1:57 PM...   Dec 16, 2005 - 6:32 PM
- - Bigmeanbulldog55   QUOTE(lagos @ Dec 16, 2005 - 3:57 PM...   Dec 16, 2005 - 8:18 PM
|- - Celica_At_GT   QUOTE(Bigmeanbulldog55 @ Dec 16, 2005 - ...   Dec 16, 2005 - 9:12 PM
|- - presure2   QUOTE(Bigmeanbulldog55 @ Dec 16, 2005 - ...   Dec 16, 2005 - 9:25 PM
|- - Rjb23   QUOTE(presure2 @ Dec 17, 2005 - 2:25...   Dec 16, 2005 - 9:28 PM
- - lagos   ok...i got a new saying then ....if it aint broke,...   Dec 16, 2005 - 10:11 PM
|- - Celica_At_GT   QUOTE(lagos @ Dec 16, 2005 - 8:11 PM...   Dec 17, 2005 - 7:23 AM
- - lagos   did u redo the compression test? what were your n...   Dec 17, 2005 - 2:05 PM
- - afroman   just gonna throw this out there but i was always t...   Dec 17, 2005 - 2:30 PM
- - zipstrips   why didnt you go back to the shop that installed t...   Dec 17, 2005 - 6:05 PM
|- - Celica_At_GT   QUOTE(zipstrips @ Dec 17, 2005 - 4:0...   Dec 19, 2005 - 7:22 AM
- - zipstrips   i still dont fully trust your standalone. find ano...   Dec 20, 2005 - 12:40 AM
- - lagos   yeah thats not enough compression for the engine t...   Dec 20, 2005 - 12:44 AM
- - 3rdgen3SGTE   It's time to install JE piston and do a oversi...   Dec 23, 2005 - 10:44 PM
Lo-Fi Version Time is now: August 27th, 2026 - 11:31 PM
